ACD lights on in hot weather..any ideas?
Old Apr 18, 2012 | 03:12 PM
IgotabigEVO's Avatar
Just like the title states all 3 of the ACD lights turn on only on hot days. We've had some nice weather here in MA a few days in the 80s & 90s and ive noticed that all the ACD lights are on on these really hot days. Is it the pump thats maybe going or something else? Just wanted to hear some sugguestions from you guys thanks in adanced!
Old Apr 18, 2012 | 06:47 PM
warstang27's Avatar
usually all 3 lights on means bad pump. it could possibly be old fluid. not sure the last time you changed it but that would be a good place to start
Old Apr 18, 2012 | 06:50 PM
Poloiceberg's Avatar
I'm having the same issue, anyone else?
Old Apr 18, 2012 | 07:13 PM
Ya i figured it might be the pump but i just thought it was weird that it only happens when its hot out.
Old Apr 18, 2012 | 07:14 PM
yacubkep's Avatar
Veteran: Air Force
mine are on.. but my pump is shot.
Old Apr 18, 2012 | 07:17 PM
evo unknown's Avatar
Have you installed a clutch recently? If so, the ACD needs to be reset.
Is it coming on immediately after you start driving the car, like within a mile? Or is it coming on after driving for a couple minutes in the heat?
Only way to really tell is to have it scanned however, it sounds like the pump has gone bad.
Old Apr 18, 2012 | 07:43 PM
lan_evo_mr9's Avatar
Most likely you need a pump rebuild. As the weather heats up and the fluid thins out, the pressure will drop from the corrosion in the pump.
Matt
Old Apr 18, 2012 | 08:10 PM
siceclipse's Avatar
this!
Old Apr 19, 2012 | 03:16 AM
silverIXMR's Avatar
Yea bad pump mine did the exact same thing. How many miles do you have? Westboro mitsu warrantied mine
Old Apr 19, 2012 | 04:49 AM
Ya it comes on after driving a few min in the heat.
Old Apr 19, 2012 | 04:53 AM
I only have alil over 16k, i picked my evo up last Oct with only 12k on it but the car sat alot as u can tell by the mileage so ive had to replace a few things here and there, i guess this will be just another thing on my check list.
Old Apr 19, 2012 | 04:55 AM
Thanks everyone for all your input! Definitely going to get the pump checked out cuz i cant stand to look at all three lights on haha. Thanks again!
Old Apr 19, 2012 | 09:14 AM
mcm308's Avatar
That's exactly how mine started... lights would only come on when it was hot out. Then after a little while, they came on and stayed on.. checked the codes and its the pump.
Old Apr 19, 2012 | 02:36 PM
deadmeat's Avatar
Happened to mine a few years ago. Hope you still have your warranty...
Old Apr 19, 2012 | 03:06 PM
Probably not if it's an '06, but can't hurt to ask the dealer. There are rebuilding options on the market now which is good
