Headlight adjustment
Old Apr 24, 2012 | 06:57 PM
barneyb's Avatar
Originally Posted by llDemonll
then you didn't reset them.
if you're going to post and say nothing here is helpful for you, post what you did.
I was saying that what has been described is not right so don't do it. I figure that's information.
Go to
https://www.evolutionm.net/forums/ev...t-03-evo8.html
and scroll down to the nice photograph. Notice the part labeled cable. See where this goes to a green wheel with teeth. There is a hole in the plastic on the front side of the wheel. Come in at a slight angle from the fog light side with a long shanked phillips screwdriver and turn the green wheel. This is the vertical adjustment.
Old Apr 24, 2012 | 08:37 PM
llDemonll's Avatar
I'm adjusting the exact same thing...the only thing i did different was remove the cable because mine were bound up and prevented me from turning the low-beam adjustment the same way he did without fear of stripping the teeth inside the housing
Old Apr 24, 2012 | 08:56 PM
barneyb's Avatar
Okay, sorry, when you mentioned removing the front bumper I stopped reading there. I did mine with the headlights on without any problem.
Old Jul 19, 2012 | 08:29 PM
Coqui's Avatar
In the pic above..the gear/10mm bolt above fog light..just wanna confirm..that adjust the foglight beam?
Also I did thread else where..but believe gear to drivers side hi beam is stripped..it wont raise when I turn it..I used the steps provided here to adjust lights (disconnected cable and just 5mm hex). My hi beams are not aligned, and also noticed one fog is slightly lower than other.
tiesto14
14
May 19, 2016 08:52 PM
Tommyy
12
Nov 3, 2015 05:52 AM
2011gts
Lancer How Tos / Installations
Jan 17, 2014 02:10 AM
Failed_1
Oct 10, 2008 03:57 PM
