Headlight adjustment
Old Apr 23, 2012 | 08:37 AM
Wish2345's Avatar
I have looked through several threads about people trying to adjust their low beam headlights and i have tried everything but actually taking the headlights out and adjusting. Has anyone figured out the correct way to adjust the low beams or have i just looked it over in a thread? I dont mean to make another post but driving at night is driving me crazy.
Old Apr 23, 2012 | 09:18 AM
gsrboi80's Avatar
So you are saying the adjustment switch in the cabin is as high as it goes and they are still not high enough??
Old Apr 23, 2012 | 09:20 AM
AdvanRG2's Avatar
I need answers as well! The switch in the cabin can only go so high!
Old Apr 23, 2012 | 09:21 AM
Tpatterson's Avatar
Ya you've got a problem if all the way up isn't enough, all the way up puts them way higher then safe/regulation. I keep mine on the second to the highest setting
Old Apr 23, 2012 | 09:30 AM
gsrboi80's Avatar
Yea I leave mine one click back as well
Old Apr 23, 2012 | 09:36 AM
Wish2345's Avatar
yes i have mine on the highest level and i am not saying its so bad that i cant see its just that with my car being lowered i want the headlights adjusted higher
Old Apr 23, 2012 | 09:42 AM
Tpatterson's Avatar
Ok lowered is understandable, but any higher, and you will be shining up above the horizon line, which will blind drivers down the road. It's just part of what comes with being lowered. When was the last time you replaced the bulbs? If its been a few years (or never) its time for new ones, hids get dimmer over time. Otherwise, it might be time to retrofit better projectors, the stock ones are pretty bad.
Old Apr 23, 2012 | 09:57 AM
Wish2345's Avatar
i am just wondering how to raise the low beams. The lights are plenty bright as i can see good up to the cut off line of course
Old Apr 23, 2012 | 11:43 AM
Robdeep3's Avatar
When your lowered on springs that dip the front end of the car lower, yes the switch inside is beyond it's limits. Here's just one thread with tidbits in it, there are quite a few more as well.
https://www.evolutionm.net/forums/ev...t-03-evo8.html
Old Apr 23, 2012 | 02:45 PM
Wish2345's Avatar
i will try this tonight and post on my findings. I hear its best to make sure the headlights are off when adjusting, which sucks b/c its a lot of trial and error if thats the case
Old Apr 23, 2012 | 04:41 PM
llDemonll's Avatar
I JUST did this yesterday.
Unless you have magical hands, you will have to take the front bumper off to make this an easy job.
What I did (I stole pictures from the thread above and reuploaded them because nothing is more frustrating than finding what you need with no pictures)
1. Take the bumper off, then take the headlights off. You'll have to unplug the headlights and the high beams are a pain in the *** (at least for me) to get the plugs off. I had to remove the bulbs to get the headlight off then do the plug separately.
2. Once you have the headlights off, remove the metal "shield" thing that he says to 'cut here' in this picture. Take a hacksaw and get rid of that crappy tab or bend it out of the way without messing up the bracket. I don't relaly know the purpose of the bracket, but i kept it. this WHOLE ENTIRE PROCESS of removing the bumper and headlights is literally just to remove that one tiny tab. everythign else could be done with the headlights on the car still
3. I chose to get rid of the silly cable that adjusts the low beams and high beams together. the high beam housings and stiff enough that they aren't going to move and the cable then serves no purpose except to bind up
4. put the metal shield back on the headlight, reinstall the headlights in the car. plug them in and test. once everything works, put the front bumper back on the car
5. wait til night
6. grab the biggest size phillips head screwdriver that will fit into the motor (see example) and drive somewhere with a big flat area and a wall / building you can adjust with
7. turning the screwdriver clockwise (tightening) will raise the headlights. for most people reading this, that's what you'll be doing. you must have the headlights off while doing this so bring a flashlight so you can see what you're doing. The headlights have to be off otherwise they'll auto-level and this won't work (and you might break something). I'd start with ~20 1/4 to 1/3 turns (just turn the screwdriver like normal 15-20 times) and then check. try and get the same number of turns into each light so they don't have to auto-level too much once you turn them on. From there, move the adjuster to '2' and level that to be where you want it. this will give you two notches 'up' and two notches 'down' of adjustment from in the cabin
from here it's all fine tuning, but removing that tab is the annoying part and the thing you need to do to be able to adjust the headlights from under the hood without removing anything in the future
Old Apr 23, 2012 | 07:56 PM
Wish2345's Avatar
5. wait til night
did you leave the cable disconnected? when do you set the level in the cabin to 2? do you do it before or after you adjust?
Old Apr 23, 2012 | 11:01 PM
llDemonll's Avatar
Yes I left the cables off. I was unable to turn the low beam gear with the cable attached and I removed the low beam side and the low beam was "normal" to turn so I took the other side of the cable off and kept it off
I originally fiddled with the headlight levels in my driveway but I would just go somewhere (unless your driveway works well) and set the adjustment in the cabin to 2 and then shut the lights off, adjust them up (by turning screw driver clockwise in the motors), turning them back on and checking where they are and repeat. Start with 8-10 full turns or 20 1/4-1/3 turns and see where they're at and just keep adjusting. Remember to adjust both lights before turning them back on otherwise they will auto-level to each other and you'll have to do it again
Old Apr 24, 2012 | 06:24 AM
barneyb's Avatar
My '03 Evo came from the factory with the low beam headlights set to low. The fog lights shown further down the road. Looking through this thread I don't see anything that would have been helpful when it came to resetting them.
Old Apr 24, 2012 | 11:10 AM
llDemonll's Avatar
then you didn't reset them.
if you're going to post and say nothing here is helpful for you, post what you did.
