Arp head studs without swapping the head gasket???
Old Apr 24, 2012 | 06:43 PM
EVOWRC111's Avatar
I'm going to run a FP Black with 272 cams, valve springs and more on a stock block Evo IX. I also plan to run c16 at around 33 psi boost. My question however is has anybody ever swapped arp head bolts/studs without swapping the head gasket. I was told to just swap bolt for bolt and then torque and it will work. My evo has 67k on it and most have told me that it will work fine but I want to make sure I'm making the right decision. Thanks guys.
Old Apr 24, 2012 | 07:22 PM
evo8426's Avatar
A lot of people prefer to remove the head and replace them all at once with a new head gasket, but there are others do the 1x1 method that you are asking about.
Old Apr 24, 2012 | 08:45 PM
Brsox10288's Avatar
Well to do it perfectly right you should remove the head and replace the head gasket. I did not do it perfectly, I did it the 1x1 way and I have not have had any issue's with it. I got tuned right after I did it and it held up on the dyno just fine and for many miles after. There is a order you need to follow though when doing this method. It is some where on here so I would use the search feature and find the correct thread. I torqued all the studs down to 30 pounds first, then all to 60, then finally 90 for the final one.
Old Apr 24, 2012 | 08:56 PM
sujinX's Avatar
theres a 1 x 1 swap how to thread. if i was to do it, thats prolly the way i would do it. IMO. everyone has their opinions on doing stuff.
Old Apr 25, 2012 | 01:56 PM
03evo_joe's Avatar
https://www.evolutionm.net/forums/at...lt.install.png
Ginglingston11
For Sale - Part Outs
May 8, 2016 06:19 PM
Boostlife4g63
Jan 21, 2015 10:19 AM
outtanowhere
Feb 3, 2012 08:37 AM
CardShark
Jul 29, 2011 12:35 AM
yikez
Apr 6, 2007 09:48 AM
