Weird problem with hallman.
Old Apr 30, 2012 | 07:49 PM
500evo's Avatar
I have this really wierd problem on my evo 9, I had my boost on 27psi spike and tapers to 23psi today since i was not racing i tryed to lower it a little and somthing wierd happen when i tryed to do a 3rd gear pull the psi shot up too 30+ I tryed to lower by turing with the arrow pointing to the - side the same thing happen, anyone had this problem before? Any ideas on how to fix this?
Old Apr 30, 2012 | 07:54 PM
MRolla's Avatar
Hoses crossed and careful with boost spikes like that will cause damage to your engine.
Old Apr 30, 2012 | 08:12 PM
500evo's Avatar
waste gate to the bottom of the mbc and the turbo nipple to the side?
Old Apr 30, 2012 | 08:29 PM
MRolla's Avatar
Nope other way around w/g to side . Turbo. J pipe to bottom and shouldn't turn up the boost without a tune or you will be sorry
Old Apr 30, 2012 | 08:30 PM
500evo's Avatar
I have alot of mods on my car, I am going on e85 and geting retuned. 27psi is fine with my mods.
Old Apr 30, 2012 | 08:36 PM
MRolla's Avatar
Just cause you have mods don't mean you should be hitting boost. Shouldn't be untill your tune you will lean out your engine and cause damage.
Old Apr 30, 2012 | 08:38 PM
500evo's Avatar
You know that little ball inside the mbc, when i took it all out is the ball supposed to go in first and then the spring after it? or is the spring supposed to go in first and then the ball and then put the cap back on?
Old Apr 30, 2012 | 08:44 PM
MRolla's Avatar
Just buy another one.
Old Apr 30, 2012 | 08:49 PM
500evo's Avatar
nah man its only a mbc. Do you know which one goes in first the ball or the spring? ball and then spring or spring in and then ball.?
Old May 1, 2012 | 04:18 PM
boostedmkiii's Avatar
Should be ball then spring... Then knob
Old May 1, 2012 | 04:19 PM
chrisw's Avatar
get rid of the MBC and take advantage of the GM 3port or similar.
Old May 1, 2012 | 09:04 PM
500evo's Avatar
I fixed it guys, sorry for later response. thanks everyone. mods please close thread
Josh Frye
Nov 5, 2015 10:55 AM
apeximonster
Apr 30, 2011 02:10 PM
craigbb
Sep 9, 2010 07:55 PM
Dorikun
South Region
12
Dec 20, 2006 02:28 AM
eve-slow
Feb 3, 2006 05:04 AM
