boost gauge question
Old May 6, 2012 | 06:16 AM
deadstockkpomp's Avatar
is it bad if the boost gauge needle sits like this when the car is off ? i know your gauge is fried if it sits well below in the vacuum section. pay no attention to oil pressure its not connected yet so i dont no where it should sit on ignition.
Old May 6, 2012 | 06:31 AM
BoostINurI's Avatar
Not trying to be a dick....just honest. The prosport gauges are a little on the cheap side so that kinda stuff will happen over time. Its not a big deal i would just start looking at upgrading gauges.
GL!
Old May 6, 2012 | 06:39 AM
meckert's Avatar
Its about std---think about it, its reading 2psi (vacuum) off of 0. As stated in the earlier post to get more accurate you may have to invest a little more
Old May 6, 2012 | 06:47 AM
i did not install them, these were all on when i bought the car
Old May 6, 2012 | 07:32 AM
can anyone tell my how to remove this gauge so i can try and reset it?????
Old May 6, 2012 | 07:37 AM
finesse49ers's Avatar
There is nothing wrong there really. It's supposed to be at "0" on the dot but that's nothing -2 to be concerned about.
Old May 6, 2012 | 07:59 AM
GTijoejoe's Avatar
My prosport gauge (digital) does the same thing.
My analog autometer and VDO gauge also sits just below 0.
Old May 7, 2012 | 02:22 AM
jspecteggy's Avatar
No it shouldnt be sitting at 0, if I remember correctly mine (Prosport mechanical) sits perpendicular to the ground with the needle pointing down when off. as for taking it off you can search on here how to remove that whole trim and theres 2 studs coming on the back of the gauge that may or may not be holding it down as well.
Old May 7, 2012 | 07:32 AM
llDemonll's Avatar
^ mechanical gauges should be at 0 with the car off
@OP that's nothing to worry about; if you want it perfect just buy a new gauge
Old May 7, 2012 | 12:00 PM
jspecteggy's Avatar
youre right, I just went and checked and I was looking at the wrong gauge. DOH ...mine sites just below 0, between 0 and -1
Old May 7, 2012 | 12:04 PM
llDemonll's Avatar
yea - that little error there isn't anything to worry about, it just means the gauge isn't "zero'd" and i dont think there's a way to zero them yourself, just kind of a luck-of-the-draw thing
Old May 7, 2012 | 01:16 PM
mcm308's Avatar
That would annoy the **** outta me..lol
Old May 10, 2012 | 11:44 AM
Greg@MasterMind's Avatar
I've seen many gauges sitting just below the '0' when the car is off, AEM, Autometer, HKS, A'pexi...shouldn't be any problem.
Old May 10, 2012 | 01:08 PM
deylag's Avatar
This looks normal to me and besides a gauge is just a representation of what is actually going on inside.
Old May 10, 2012 | 01:16 PM
iloveturbolag's Avatar
Most of my auto meters over the years have been around there at atmosphere, maybe a bit closer to zero but usually error to the vacuum side
