Evo IX MR Factory Front Lip Help
Old May 16, 2012 | 02:52 PM
BoostedAWD91's Avatar
How is the front lip mounted to the bottom of the front bumper on the Evo IX MR's? The driverside corner came undone and i dont see how its supposed to be held on. Is it just adhesive?
Old May 16, 2012 | 02:56 PM
tstevens's Avatar
It's held on by a bunch of small tabs, if they break you just have to glue them. You could also used double sided tape to get it to hold, that or super glue! Here's a thread I found that had some ideas on what to do about the MR lips: https://www.evolutionm.net/forums/ev...lling-off.html
Old May 16, 2012 | 06:01 PM
Thanks man, ill check out that thread. Seems like its either glue or double sided tape which unfortunatly don't seem like a permanant solution. Mitsubishi sure isnt the best with attaching parts to the body
Old May 16, 2012 | 07:25 PM
304MR's Avatar
I don't know about tabs my mine is held with around 12 screws. To remove you might as well take off the entire bumper (easiest way).
Old May 16, 2012 | 11:05 PM
importmachine's Avatar
there is a small tab there, if you don't see anything, stick a screw through the bottom and call it a day
Old May 17, 2012 | 06:12 AM
BBS's Avatar
BBS
Jb weld the tabs back on and itll be stronger than when it came off the factory floor
Old Jun 2, 2012 | 08:42 PM
FunBeny's Avatar
I just jb welded mine and it is stronger. It set in 6 minutes and became welded on in about 30 min
Old Jun 3, 2012 | 06:53 AM
superkizuna's Avatar
Nothing like the good ol'busted lip on the Evo. I'm currently driving around with a busted lip. Next week I'll get either a CF or OEM replacement.
Hoojan
Feb 16, 2017 11:33 AM
DaltonD19
Nov 13, 2016 09:02 AM
OhEvoIX
Mar 28, 2016 09:00 PM
mrowka
Aug 12, 2012 09:31 PM
orugacoja
Northwest Region
May 31, 2010 11:40 AM
