Evo fail....
Old May 27, 2012 | 12:43 PM
  #46
n2oiroc's Avatar
Originally Posted by Boosted Tuning
You should be easily able to get the motor out of the EVO in 5 hours or less, if you have the right tools.
i guess that depends on what the right tools are. i dont have a lift which sucks, but i have a good assortment of hand tools. i might just pay someone to do it. my shoulders and back are in rough shape, so its not something i should be doing anyways.
Old May 27, 2012 | 01:03 PM
  #47
Boosted Tuning's Avatar
Ahh, yeah, a good lift, engine hoist & air tools make the job much easier.
Old May 27, 2012 | 02:47 PM
  #48
EVOWRC111's Avatar
I have everything but a lift. The hoist and stand are ready but I spent 3hrs on it already and all I have left to do it disconnect the A.C. and P.S. then the mounts and its all out. Subaru is still easier though.
Old May 27, 2012 | 03:49 PM
  #49
Agreed.
Old May 27, 2012 | 03:59 PM
  #50
06MRV8Killer's Avatar
Originally Posted by batty200
To the OP overheating any engine can kill it. Sorry about your luck.
This.
Old May 27, 2012 | 04:41 PM
  #51
silverofs's Avatar
Better replace your oil cooler or you will do it all again!
Old May 29, 2012 | 02:54 PM
  #52
EVOWRC111's Avatar
Agreed.
The p.s. bolt closest to the ex manifold broke when trying to take it out. It got white hot from the looks of it. 4bolts connect the p.s. to this bracket, how important is the 1 bolt? I think it's pretty seized in there. Even after using WD-40 before it broke it didn't get any easier. Used a 2ft breaker bar in the end lol.
Old May 29, 2012 | 03:18 PM
  #53
CurseDSM's Avatar
Pb blaster is your friend not wd-40
Old May 29, 2012 | 05:28 PM
  #54
EVOWRC111's Avatar
So I just spoke to my tuner and he gave me some new info. He stated that it's not Likely that the bearing spun due to over heating. He stated that it's more likely due to an oiling issue. I know for sure that my oil was full but I am the 4th owner of this car so I don't know of any major abuse. But from the looks underneath, its been mudding a few times. Another thought is that I was in long turns at high speed and my oil pan and pickup are oem. It might have been sucking up air instead of oil in long turns at the track. If I plan on running it like this again I'm gonna need a AMS oil pan and pickup.
Old May 29, 2012 | 06:43 PM
  #55
CurseDSM's Avatar
Or overfill it by a quarter quart to a half quart to help with that. I know the oh thats not good for the motor will come out, but there are plenty of guys that do it without issues.
Old May 30, 2012 | 07:45 AM
  #56
deylag's Avatar
I have already installed an oil pressure gauge but not temp. The bad thing is that they are Auto Meter and do not give any warning like Prosport or Defis. And boost leaks test can only be tested by running it from what I can think of. The coupler that broke was riding against the rad shroud for what looks like a really long time. Fixed now though, day late and $4k shorter.
I do all my boost leak tests with the motor off. Here is a thread with more info:
https://www.evolutionm.net/forums/ev...er-5-02-a.html
Old May 30, 2012 | 08:03 AM
  #57
AF-Evo8's Avatar
Go with the buschur baffled Oem oil pan and make sure you replace your oil cooler so you don't get any shavings/ debris in your shiny new engine. I have MAP's oil cooler and would highly recommend it.
Old May 30, 2012 | 08:53 AM
  #58
EVOWRC111's Avatar
PICTURES!!! Well it was not a rod bearing, but what caused it.... overheating???
[img=http://img43.imageshack.us/img43/1475/img500d.th.jpg]
[img=http://img803.imageshack.us/img803/3544/img499.th.jpg]
[img=http://img717.imageshack.us/img717/6743/img498d.th.jpg]
[img=http://img834.imageshack.us/img834/8691/img497.th.jpg]
[img=http://img406.imageshack.us/img406/1134/img496s.th.jpg]
[img=http://img341.imageshack.us/img341/6084/img495.th.jpg]
[img=http://img820.imageshack.us/img820/4525/img489f.th.jpg]
[img=http://img818.imageshack.us/img818/6003/img486f.th.jpg]
[img=http://img32.imageshack.us/img32/4389/img485d.th.jpg]
Old May 30, 2012 | 09:06 AM
  #59
CurseDSM's Avatar
Wow thats terrible. After looking at the pics being you said others have owned it does this motor have oil squirters? I know you can take them out with built motors but not for stock apps.
Old May 30, 2012 | 09:32 AM
  #60
EVOWRC111's Avatar
Yep, their still there.
