Balance shaft, keep or get rid of it?
Old May 23, 2012 | 10:59 PM
EVOWRC111's Avatar
Question Balance shaft, keep or get rid of it?
One major question..... The balance shaft, if I decide to keep it, will it hold me back in power? Is there anyone out there that running their 600hp plus Evo with the balance shafts till in?
Old May 26, 2012 | 12:42 PM
rrstlevo's Avatar
those balance shafts spin twice crank speed... if the whimpy belt for it breaks thats the end of it. mitsu puts those in so you dont feel the engines vibrations in your seat. good insurance to gid rid of them.
Old May 27, 2012 | 10:24 AM
EVOWRC111's Avatar
Good deal, thanks
Old May 28, 2012 | 10:32 AM
rrstlevo's Avatar
Oh and use this to eliminate the balance shaft.
http://www.amsperformance.com/cart/A...nator-Kit.html
Or one like it. Or have your machine shop
Grind the one you have. If you use the stub shaft it puts excess stress on the oil pump which I have experienced a pump failure before. I had my machine shop cut mine and havent had any issues.
Old May 28, 2012 | 05:45 PM
djdnav's Avatar
We Took the shaft out of my buddys 4g64 motor and it did increase the vibration a lot. It probably picked up 5-7 hp.. But I've been told by reputable sources that it's best to have the motor balanced if you eliminate the shaft.
Old May 28, 2012 | 06:04 PM
tundeclips's Avatar
PM teal2nnr..
Old May 29, 2012 | 05:02 PM
EVOWRC111's Avatar
MAP is building my block and they are doing their style of balance shaft removal. I requested the AMS style do to hearing about the oil pump failure but they stated that they have had no oil pump failure to date with the way they do it. I looked it up and have yet to find anybody using MAP that has had problems with theirs. If you know of anyone using a MAP block that has has the issue please have them pm me. Thanks
Old May 29, 2012 | 05:04 PM
AJCaron12's Avatar
Anyone else have an opinion on keeping or removing the balance shaft? Any experiences with it removed?
Old May 29, 2012 | 05:09 PM
foxbear2277's Avatar
My build will not be seeing the balance shaft, all companies I talked to about my engine build, told me to delete the balance shaft
Old May 29, 2012 | 05:19 PM
AJCaron12's Avatar
Yeah but how bad will vibrations be with it removed?
Old May 29, 2012 | 05:26 PM
It cant be that bad, my evo with solid lower crossmember/motor mount and all other ts motor mounts vibrate more than my buddies evo with a 2.3 with no balance shafts (hes on all stock mounts).. Now having solid mounts and 2.3 with no balance shafts.. I have no clue but thats why I thought the idle is higher on a built car... less vibrations felt at idle
ReivaXVrai2
75
Jan 21, 2017 07:28 PM
chizz
Jun 22, 2016 03:15 AM
honda-guy
40
Aug 2, 2015 07:37 AM
EvoJoeIX
May 22, 2013 07:25 PM
jason42003
May 14, 2012 07:46 AM
