Ignition Power Issues
Old May 25, 2012 | 09:26 AM
80210's Avatar
I'm having trouble starting my vehicle. Radio and rest of car gets power but the turbo timer which is hooked up to the ignition has no power. I checked ground and all wiring as well as interior fuses and all are ok.
Old May 25, 2012 | 10:14 AM
djdnav's Avatar
Possibly a bad clutch switch. Try unplugging it.
Old May 25, 2012 | 12:04 PM
80210's Avatar
UPDATES PLEASE HELP
-Fuel pump is making noise so don't think its that
-Got a gallon of gas to be certain I wasn't running on fumes
-All Fuses are ok
- Radio and other guages work, so I don't see why it would be the battery
What should I do next? Could it be a immobalizer issue? I don't know what would cause that though. Why don't I have power to my turbo timer but I have power to everything else?
Old May 25, 2012 | 06:41 PM
lostsoulsevo's Avatar
use a amp meter? your turbo timer could be dead....electronics do break. does the vehicle start?
Old May 25, 2012 | 09:33 PM
djdnav's Avatar
If you have access to a Tactrix cable I would download "ecu unlocker" and give it a shot.
Old May 27, 2012 | 10:55 PM
80210's Avatar
Was simply a dead battery thanks for the input though, I guess the turbo timer must be broken which was throwing me off but all is good now
NJ_evoIXgsr
Mar 9, 2017 05:57 PM
turbotaloon95
Apr 11, 2016 06:58 AM
rhitme03
Jun 6, 2011 01:50 PM
bbyevo8u
Dec 20, 2009 09:28 AM
AndyC
19
Apr 26, 2005 04:09 PM
