Greddy Profec B spec 2 Filter
Old Jan 26, 2004 | 06:02 PM
ThEHiTMaN's Avatar
I got my Greddy profec B spec 2 installed today and noticed they did not install the Filter that goes between the pressure source and the EBC control unit running to the inside of the car. I was wondering how important this piece is. The manual says this MUST be installed. But then why didn't they install it? I was wondering if any of you left it off or not? I could always just cut the vac line and put it in there. Also the manual says you must put it in the right way but when u look at it there is no indication of which way is right....
I have a K&N Cone filter and 3" cat back does anyone with similar mods have some good settings? I am looking for some lo and hi settings.
MY hi
Gain 20%
Start 17 psi
Boost 50%
warning 20.5
Limmiter set to 40%
These seem to hold 19 ish....
Old Jan 26, 2004 | 06:07 PM
evoego's Avatar
Registered User
might want to change start to 13 and warning to 22, but with no fuel control just be careful
good unit though holds boost well
Old Jan 26, 2004 | 08:14 PM
ThEHiTMaN's Avatar
Nevermind I just installed it took a total of 5 min. LOL
Old Jan 26, 2004 | 08:22 PM
ThEHiTMaN's Avatar
How about max boost setting? I have been reading on here about the most boost you can run with no AFC on a fairly stock evo except K&N cone filter and 3" cat back exhaust. I have heard anywhere from 19-22 psi? Can I get some opinions on that?
Thanks
RobertIsl
Apr 27, 2017 10:29 AM
stefano
Jul 23, 2010 10:15 AM
JaReDbOy
Jul 2, 2006 09:40 AM
El Boricua
38
Mar 31, 2005 07:20 AM
ThEHiTMaN
Jan 29, 2004 09:40 PM
