Aem Digital Boost gauge help
Old Jun 10, 2012 | 07:17 PM
lcwjr's Avatar
I removed the entire factory line when I changed gauges. As you know, its a pretty long run. Like kanovic, I mounted the AEM sensor under the hood on the right side strut tower, about 12 inches or so from the T-fitting. So, I cut off a section of the original line, and used that. I'm still puzzled to this day about the presence of the pill. Maybe someone who has to push those restrictor pills into the boost controller lines, put one in the wrong line by mistake. I don't know. Probably never will.
Old Jun 11, 2012 | 02:47 AM
asu11's Avatar
Another thing you might be noticing is the gauge sitting at zero when you start spooling under light throttle, but it is not actually going out of vacuum. Mine does the same, I can hear the turbo spooling and my bov will release but my AEM will read 0. I have not done a comparison with an analog boost gauge but now I want to test it.
I also don't think the pressure differential between the longer line lengths would make a difference in the gauge reading since it is not drastically long. If you have the same line id all the way through it shouldnt cause a problem. Assuming there isnt any kinks.
Old Jun 11, 2012 | 04:47 AM
kanovic's Avatar
Yep mine does the same thing under light load I can tell I'm building boost but it just reads 0. I will check for the pill tonight and see if there is one.
Old Jun 13, 2012 | 04:07 PM
kanovic's Avatar
Looked for the pill and no luck the line is fine. Anyone else?
Old Jun 14, 2012 | 12:08 AM
asu11's Avatar
Same here no pill. It would be cool if someone compared an analog gauge to digital.
Old Jun 15, 2012 | 08:25 AM
89turbosupra's Avatar
I installed my aem boost gauge last night and am having the same exact issue as well. I used the factory mr vacuum line and simply plugged it into the aem sensor. I guess I gotta try something else.
Insanity Evo
Jun 14, 2016 06:45 AM
cpunlamd
May 6, 2014 04:08 PM
FameEvo
Dec 18, 2013 08:30 PM
King Mercenary
Mar 14, 2011 10:52 AM
stevolee
12
Apr 15, 2010 08:32 AM
