Idle Issue
Old Jun 11, 2012 | 10:08 PM
Spirit evo 8 MR's Avatar
Post Idle Issue
Had my Evo tuned while back, even though i should of addressed this issue before, i did not. now we are due for the inspection, and my remarkable check engine light will fail it the problem is in idle control: car often idles too high triggering the code... went to tuner several time and raised the idler high to avoid the issue, but it keeps coming back, due to random idling range, (1000 to 2000rpms). throttle body is Buschur ported, i was told throttle body sensor might be bad or malfunctioning, so before i will tear it down any ideas or suggestion?? did anyone had this type of problem? if yes how did you got it fixed??
Any help is appreciated and thank you ahead of time.
Old Jun 23, 2012 | 10:49 AM
i guess nobody has an input on this?? common guys, someone must of ran this issue before...
Old Jun 23, 2012 | 04:53 PM
brakeboost980's Avatar
How many miles on your sensors??
Old Jun 23, 2012 | 04:55 PM
thedru13's Avatar
do you know what code its throwing? did you check your IACV or see if the BISS screw is still there?
Old Jun 27, 2012 | 09:21 AM
little over 58000....
Old Jun 27, 2012 | 09:24 AM
The code is P0507 says Idle Air Control system Revolutions Per minute Higher then expected.
Not yet, but will do
Just did, everything there
Old Jun 27, 2012 | 09:32 AM
thedru13's Avatar
Start there. If you need some help I am not that far from you..
Old Jun 28, 2012 | 01:04 AM
jrblackSE's Avatar
I have same issue. Mitsubishi says its the IACV. Which is somewhere near 300 new. They recommended cleaning it out with carb cleaner but try not to spray it directly in the sensor. Good Luck
Old Jun 28, 2012 | 08:31 AM
Thanks for the input on this guys, will try over the weekend different things to get it working
9!'clipseDOHC
Jan 9, 2016 10:21 PM
LeXcite
Dec 5, 2015 02:33 AM
kamote2000
May 9, 2015 03:55 AM
Live4Redline
Lancer Engine Management / Tuning Forums
49
Aug 23, 2012 09:50 PM
BlackDismay
Dec 12, 2011 06:05 PM
