does this sound normal?
Old Jun 13, 2012 | 04:18 PM
Initial_r90's Avatar
Recently I dont know if I never picked up on it or what but there is a noise coming from my engine could be normal but I'm not an evo expert yet. I recently did a single spring mod to rid the turbo of surge dunno if its leaking now tho my boost gauge says 23psi but I dont know. I also just changed to plugs from stock evo 8's to 1 step colder coppers. Also the intake I assume makes a whistle at idle when IAC goes on and off I guess?
let me know what you guys think.
40k miles
evoVIII turbo with 10.5
o2 open dump,Downpipe,catback
HKS 264/264 cams
ARC intake with HKS pipe
ETS LICP
255 pump
MBC set at 23 psi
Ivey tuned with just the intake cams and catback
the owner before said it made 315whp
https://www.youtube.com/watch?v=dmz4...4&feature=plcp
Old Jun 13, 2012 | 07:25 PM
EclipseMblue's Avatar
you should use NGK BPR7ES plugs, sounds normal. if anything its just a clogged lifter from what i can hear in the video
Old Jun 14, 2012 | 05:12 AM
I took out BPR7es and put in bpr8es
Old Jun 14, 2012 | 06:11 AM
Sil'vr-Boi6's Avatar
Why not revert back to without the spring mod to see if problems persits? Plugs are gapped, where?
Old Jun 14, 2012 | 06:20 AM
plugs are @ .24
Old Jun 14, 2012 | 06:30 AM
mcm308's Avatar
Noises are hard to discriminate against in videos. Sounds like it has some lifter noise and some slight timing belt whine? was the t-belt ever changed ?
Old Jun 14, 2012 | 06:48 AM
No it only has 40k on it its stock as far as I know.
Old Jun 14, 2012 | 11:04 AM
mcm308's Avatar
Yea, I only asked because it's cammed. They might of changed the belt at the same time. And also might of skipped pulling out the lifters and bleeding them.
Im gonna send you a PM
IveyTuneX
Evo X Dyno Results
35
Sep 16, 2019 09:30 PM
astral
Sep 26, 2016 10:55 AM
EvoVIII_03
Apr 10, 2012 08:15 PM
berkel
Mar 3, 2005 09:49 AM
evo 8 ya
Feb 24, 2005 09:13 AM
