All ACD lights on.... Need a new pump?
Old Jun 14, 2012 | 11:55 AM
evo*7*'s Avatar
I only had acd bled and oil changed a few months back, however recently all 3 lights come on shortly after driving and stay on, does mean a definite new pump or could it be something else not as serious?, i wont be able to make it to the mechanic for a week or two..
Old Jun 14, 2012 | 03:29 PM
elhalisf's Avatar
your ok to drive it with the lights on.
Old Jun 14, 2012 | 03:45 PM
EVO8emUp's Avatar
Mine also came one the other day.
I plan on getting a rebuild kit from ACD tuning.
http://www.acd-tuning.com/evo-7-9.html
Old Jun 14, 2012 | 03:58 PM
lan_evo_mr9's Avatar
You most likely need a pump rebuild. If the lights came on directly after the oil change then I'd say it's related to that, but since it's been a while, then probably not.
Old Jun 14, 2012 | 07:30 PM
pacent's Avatar
Scan it first. Mine came up with a code 82, which meant there was a problem with the pump. I tried bleeding, but ended up taking it to the dealership to replace the pump under warranty.
Old Jun 14, 2012 | 08:12 PM
gpfury86's Avatar
I messed with the acd pump and got it working then it started leaking through an o-ring cause the damn thing was corroded to ****. I was over it, im currently in the process of getting a non acd t-case built and just gonna pull all the lines and garbage off. Less weight and acd is junk for what im gonna use the car for anyway lol.
Old Jun 14, 2012 | 08:38 PM
MXPi Tuning's Avatar
The ACD defaults to an open diff at pump failure.
Old Jun 14, 2012 | 08:47 PM
gpfury86's Avatar
When my pump was bad and the system was completely pressure less it would be about 50/50 sometimes I would mat it and it would squat and go and sometimes it would blow the front tires like I was in a complete FWD car...... annoying to say the least.
Old Jun 15, 2012 | 07:56 AM
Redline-Z's Avatar
Veteran: Air Force
My ACD pump is shot also and I just blew my tires off yesterday and was like WTF that never happened in 2nd gear before. It must be from the open diff?? It left marks out the back of the car I could see in the rearview.
Old Jun 15, 2012 | 09:17 AM
casual's Avatar
thanks for the link, i was gonna buy a new one but might go this route. anyone have experience with this?
Old Jun 15, 2012 | 09:49 AM
Boostin_AWD's Avatar
There are several things to check first before jumping to a new pump. I also had an acd fault, with a little time and effort plus alot of reading I fixed it. First thing is first to the op and everyone else, does the pump opperate? Key on, car off, push gas pedal to the floor and hold for 5 or so seconds. Pump should turn on.
Old Jun 15, 2012 | 09:54 AM
casual's Avatar
actually tried that and the pump did not turn on.
Old Jun 15, 2012 | 10:02 AM
K the acd works off steering angle if im not mistaken, I noticed with the wheels turned the pump wouldnt prime. Make sure the wheel is straight. After you tried that procedure did the lights come on, if and when they did could you hear a relay click?
Old Jun 15, 2012 | 10:40 AM
TJs98GT's Avatar
All the lights are on on my dash as well, when i turn the key forward and push the gas pedal in I hear a whining pump noise, so that means my pump is ok?
Old Jun 15, 2012 | 10:54 AM
Not exactly. That just rules out a power issue to the pump, which was the road I was heading down for the other member who posted his pump is not opperating. In your case the pump works, but that doesnt mean its building pressure. Have you checked your acd code(s)?
