Suggestions: Should IC be next?
Old Jun 25, 2012 | 08:16 PM
ILoveAWD's Avatar
Originally Posted by black_beauty
If he has evoscan and a tactrix...
true!
Old Jun 26, 2012 | 05:59 AM
mcm308's Avatar
Change the IC piping and FMIC and just get it over with. Problem is the stock FMIC was designed to work well with a stock turbo at stock boost levels. When you get your car tuned and start to push the stock turbo into higher boost levels, it creates heat and the stock pipes and FMIC can't keep up, especially on pump gas. E85 is a different story.
Old Jun 26, 2012 | 06:22 AM
thepoint4life23's Avatar
You Can wire a switch in the car that will let you go from a e85 map to a gas map
Old Jun 26, 2012 | 12:38 PM
Ideal IX's Avatar
Thanks guys
I'm reevaluating the E85 option.. There is an E85 station about ~10 minutes away from my work. Waiting to hear a response from the tuner.
Thanks for the suggestions.
Old Jun 26, 2012 | 12:55 PM
black_beauty's Avatar
Everyone raves about e85, im about to do it myself. Been looking for a good e85 base map though...
Old Jul 5, 2012 | 10:26 AM
evodriver49's Avatar
yes id say get at least a reputable (no turbo xs ebay bs) 3" intercooler no bigger than 3.5" and a good licp (ets, muse, ams, etc) and uicp IF you wanna feel "complete" but they dont make much power unless you go short route with a mini battery!
Old Jul 5, 2012 | 10:55 AM
chris the man's Avatar
well if he is in cali, shouldnt he be looking at cooling e85/meth radiator and piping vs the core?
Old Jul 5, 2012 | 10:56 AM
hell yeah agreed to that
Old Jul 5, 2012 | 11:13 AM
ToddRhodes's Avatar
I'm only around 340 whp on VD and just replaced my FMIC with the ETS 3.5" wide kit. They don't make much/any power innately, but they give you more cushion to add timing up top and still cool the air enough out of a stock turbo to ward off knock, not to mention the beating a stock FMIC would take on a track. My car came with injen upper and lower hard pipes so I just had to replace the core. Took an hour to do. I'd rather have peace of mind that multiple pulls in a row aren't going to heatsoak the FMIC and potentially cause issues with knock.
Old Jul 11, 2012 | 11:10 AM
Ideal IX's Avatar
Thanks for all the reply guys. I'm going w/ the 3.5 ETS intercooler kit w/ the mini battery. Can't wait till I get the car setup and done.
I'm just waiting for one of the 2 tuners i'm inquiring about (GST/FFTEC) for a reply. A few days have passed and nothing yet.
I am definitely doing E85 and whatever is necessary to be able to change from one map to the other.
Thanks again!
