Burping the radiator question
Old Jun 25, 2012 | 06:35 PM
xRoguex's Avatar
the right funnel/system is the correct way to burp it.
You need to get the coolant level as the highest part on the motor.. and the TB is higher then the rad cap on a level surface.
Old Jun 25, 2012 | 07:28 PM
fastyouth1313's Avatar
That is a very good point! Hence why with vacuum/pressure broken with the radiator cap off the funnel still has coolant in it and it's about level with the TB
+1 for dropping some physics!
Old Jun 25, 2012 | 08:16 PM
xRoguex's Avatar
Correct. Thats why the kits you see make it like 1 foot high.
Old Jun 25, 2012 | 08:21 PM
My black funnel trick worked, that was my pic. But it makes a lot of sense though. Thanx!
Old Jun 26, 2012 | 04:58 AM
TommiM's Avatar
Theres more than one way to skin a cat, funnels work nicely too. But seriously no offense, 2 pages of this thread to ask how burp your coolant system?
Old Jun 26, 2012 | 06:58 AM
st00pidct9a's Avatar
Originally Posted by Macaroni
I don't know about others here but it usually takes me 15 minutes or more after it's warmed up to burp the system. Picture someone just standing there with a jug of coolant and the hood popped concentrating on the coolant level for 15 minutes or more haha.
x2, i was getting hella impatient lolz
Old Jun 26, 2012 | 08:01 AM
thats was me! just sitting waiting.... hoping for some big burp or huge bubbles...but just a few small ones
Old Jun 26, 2012 | 01:04 PM
barneyb's Avatar
Okay, here is how to do it without the funnel. BTW, funny, the funnel is used to keep from making a mess. So, now you are done and still have coolant in the funnel. Mess.
Fill up with coolant and start engine. As whatever is in the engine (air, coolant) expands from the heat of a running engine, the coolant will overflow. So, put your hand over the cap opening. The extra coolant will go to the jug. Finally, when the thermostat opens the level will go way down. Dump in more coolant and cap. Fill the jug to the full level. Done.
Watch the jug level for a couple days. The level may go down a little as any remaining air comes out. Top off the jug.
Old Jun 26, 2012 | 01:28 PM
i wrapped an old beach towel along the base and slowy pulled the funnel. the towel caught nearly every drip. i need to go check it though now that is cooled
the whole reason this happened was because i installed a new turbo and upon start up it shot coolant diretcly onto the manifold, it was a pinned sized hole..... so now the little pin hole is JB wleded ( i know...keep your comments on this down haha its only temporary) New Mishimoto RAD gets here friday.... i hope the filler neck is the same sizr as the funnel i used on the weak *** OEM one haha
Old Jun 26, 2012 | 01:31 PM
tscompusa's Avatar
you need something like a Lisle funnel where you can allow the coolant to get into the funnel and bubble out the air bubbles. the last time i got air in my car it took 15min of idling with coolant bubbling in the funnel.
jpholbert
Aug 12, 2015 11:54 AM
jasonn
21
Nov 4, 2014 08:52 PM
TeachersEvo
Jul 31, 2012 06:54 AM
Dream Came True
15
Jul 10, 2012 01:04 AM
