speed density question?
Old Jun 26, 2012 | 11:02 AM
brunz44's Avatar
i brought my car to have cams put in and tuned on speed density to help deal with
the idle ect. i got home unplugged the maf to drive and it ran like crap barley ran
actually. Is there a step i have to do myself before removing it. Or did my tuner
just charge me an extra 150 and say he switched it over to SD. Car was still jumpy
coming off the throttle. Im pretty confused if someone can explain what the deal is
that would help me alot. Thanks
Old Jun 26, 2012 | 11:12 AM
chu's Avatar
chu
There are no specific way to remove the MAF; unbol it, and remove it. When the tuner converted you to speed density, he/she should have removed the MAF for you, and tune the car without it. So, you should go back, discuss your issue with the car and the tuner, and have them check it out.
Old Jun 26, 2012 | 11:21 AM
Tekniq's Avatar
Did you install a 4 Bar Map sensor and the GM Intake sensor?
Old Jun 26, 2012 | 11:32 AM
brunz44's Avatar
Ill have to call and ask when I was talking with the tuner he said to help with the idle with the 272s that he would put it on sd didn't ask what version so you guys think it wasn't switched over?
Old Jun 26, 2012 | 11:44 AM
06RedRalli's Avatar
I'm going to say that it didn't get done.
Old Jun 26, 2012 | 11:45 AM
Tekniq's Avatar
We don't have enough information. But it doesnt look good.
Can you post a picture of your engine bay?
Read up here:
https://www.evolutionm.net/forums/ec...e-logging.html
and here:
https://www.evolutionm.net/forums/ec...tructions.html
Old Jun 26, 2012 | 11:51 AM
brunz44's Avatar
Read up here:
and here:
Thank you for the links . Going to go take a pic now, any info you need on the mods just lmk I appreciate everyones responses
Old Jun 26, 2012 | 11:52 AM
fastyouth1313's Avatar
check your UICP for a and IAT sensor..... if there is no sensor then there is no speed density.
or maybe the tuner put in a hard to reach spot. check the wire that plugs into you maf see if there are 2 stray wires running off somewhere in the engine bay if there arent then you know there is no speed density. If there are wires follow them and you should find your IAT.
kinda sounds like you get flim flammed
Old Jun 26, 2012 | 12:04 PM
chu's Avatar
chu
FALSE. Speed density can be done using the fuel temp sensor to mimic air temp. That's what I have done, using Tephra, and works flawlessly.
IMO, you guys are approaching this wrong. The OP paid someone to do the work, so that should be his first approach. Go back to the tuner, and figure it out together. If the tuner can't get it right, ask for the money back. Also, there is no need to go SD because of those cams.
Piece of advice: You guys who are paying for labor need to wise up and do some research before taking you car to let a shop work on it. If it doesn't sound reasonable, ask some questions. Have a clue what you're doing, and getting into before your hard earned money leaves your pocket. You should be able to leave a shop with a certain level of confidence they did the work you asked of them.
Old Jun 26, 2012 | 12:07 PM
Tekniq's Avatar
How can they figure it out together if the OP doesn't know what speed density consists of?
Thats why I posted the links so the OP could familiarize himself.
Old Jun 26, 2012 | 12:13 PM
chu's Avatar
chu
What you posted it great, there's no question about it. I'm in no way questionning anything. The fact is, he paid for the work, so he should start by asking the tuner these questions. Let's not take this out of context.
Old Jun 26, 2012 | 12:24 PM
brunz44's Avatar
Im familiar with sd
Old Jun 26, 2012 | 12:30 PM
brunz44's Avatar
I was just curious what everyone else had to say about this situation but obviously this went in the wrong direction thanks to the ppl that actually tried helping.
Old Jun 26, 2012 | 12:32 PM
JohnBradley's Avatar
You can send your ROM to me and I can see if it was even setup in the programming.
Old Jun 26, 2012 | 12:43 PM
brunz44's Avatar
Im having my buddy with a t-cable look once he stops over there's no way its sd running how it is with MAF unplugged. Once I get a call from the tuner ill update if its on sd or not transfered thanks again everyone
