Patch radiator? Or not.
Old Jun 26, 2012 | 03:35 PM
pignosesr's Avatar
So my radiator is leaking from the core. When on it shoots out like a squirt gun onto the turbo. The hole is tiny and I'm just wondering if I could get it patched by a shop? Is it recommendedm? Or should I just go for a new one? Again the hole isn't big at all.
Old Jun 26, 2012 | 04:15 PM
finesse49ers's Avatar
My GSX is running a Mishimoto 3 row radiator that had the fins damaged, however I never used it until I had it repaired by a radiator repair shop but I'm positive the damage was enough to cause leakage. If yours is a tiny hole then certainly it can be saved.
Old Jun 26, 2012 | 04:33 PM
pignosesr's Avatar
^ Great thanks for the info! Are there any trusted shops you guys would recommend bringing it too?
Old Jun 26, 2012 | 04:36 PM
Evoardo IX's Avatar
Is it broken in the aluminum part or the plastic type part?
Either way, I would not risk any future leaks or headaches, find a cheap used core in good condition ( fs forums, ebay, etc ) and replace, that's what I would do.
Old Jun 26, 2012 | 04:44 PM
fastyouth1313's Avatar
i had the exact same squirt on one of vertical seams, i used jb weld as a temp fix while my new mishimto is in the mail.....
I used it as an excuse to upgrade! you should do the same, i bought mine of a guy on here for cheap.
Old Jun 26, 2012 | 04:51 PM
WICKEDevoEIGHT's Avatar
if it is in fact a small hole, and easy to see/get to, you can patch it as a temp fix. Mine lasted awhile and then I ordered a new one and threw that in once I got it. I used water weld by jb weld and it worked fine.
Old Jun 26, 2012 | 06:43 PM
sho669's Avatar
If its one of the tubes leaking in the core (which is my guess given your description) it's a very simple fix for a radiator shop or you can do it yourself. A small pair of needle nose pliers can be used to pinch the hole/tube shut. One tube isn't going to hurt the performance of the radiator a noticable ammount at all.
Radiator shops can be kind've hard to find anymore as people like to replace parts rather than fix them and save a little cash. Just stay away from the stopleak crap, it's like cancer for your cooling system.
Old Jun 27, 2012 | 10:48 AM
TigOLDBiTTies's Avatar
i used a patch kit from pepboys about 7,000 miles ago. just use another 2 inches of the putty stuff and make sure u really get it inside the fins to stick well. im gonna replace mine soon with a mishismoto evo 6 rad that has a straight shot to the coolant pickup.
Old Jun 27, 2012 | 11:03 AM
gsrboi80's Avatar
You can go old school as a temp fix and just crack an egg in there. It does actually work
Old Jun 27, 2012 | 11:06 AM
Kracka's Avatar
The radiator on my IX got punctured during a clutch job, the shop doing the clutch install had a local radiator repair shop fix it and I never had an issue with it.
Old Jun 27, 2012 | 12:32 PM
st00pidct9a's Avatar
or pepper
Old Jun 27, 2012 | 12:35 PM
CtSilver03Evo's Avatar
I had this issue with a Koyo radiator in my old turbo Nissan and I used JB Water Weld to patch it... It worked great for the few years I had the car. No issues!
...Also, I can see the previous owner of my current Evo had the same problem and patched it with the same thing HAHA. Again, I've had my Evo for 2.5Yrs, no issues with it letting go!
Amazon Amazon
Old Jun 27, 2012 | 02:06 PM
AWDBus's Avatar
Take it to a rad shop and have it fixed right. They can leak test it also.
Old Jun 28, 2012 | 12:54 AM
jrblackSE's Avatar
The cooling systems on these cars are very important. I would just spend the little amount it would actually cost and get a new radiator or a solid used one. I would hate to see something bad happen for a simple little fix gone wrong. Best of luck
Old Jun 28, 2012 | 02:35 PM
jameelrose's Avatar
Mine was patched up with JBweld. Works great. Mishimoto as well.
