Boost slowly dropped in 3 day wtf??
hey guys i just recently bought a 2006 evo 9 mr, and i have a problem, the turbo will spool 4 psi now, and 3 days ago it was boosting 20psi whats my problem. car is all stock.
I would do a boost leak test with an air compressor with a boost leak tester along with soapy water. Just because you can hear the leak and feel it doesnt always acuratelyspot the leak and makes sure there isnt any you also have to see it.
If it's not a boostleak tester attached to anair compressor then im sorry my friend your did not boostleak test the car correctly. Furthermore you should invest into some tbolt clamps and ziptie down your vacuum lines for extra assurance for prevention of the loss in boost.
Say what now? uhh how did you go about checking the car for a boostleak? I dont think you did becuase if you did the car would still go into boost. Which tool did you use to boostleak test the car?
and i kinda hope this is a joke thread.
when did the bend in the ic happen? im assuming u had 20psi before, then hit something and now 4 psi?
sounds like improper placement of a jack, how did u not see that before u bought it?
This seems like a major boost leak. Most likely your intercooler is cracked and needs replacement. Otherwise your intercooler pipes have come lose or there is a big hole in one of the couplers. I would personally start by removing the front bumper to see everything.
