Question on boost levels in different gears and tuning
Old Jul 1, 2012 | 01:20 PM
Waldo's Avatar
Originally Posted by Raptord
Behind from underneath.
ok cool thanks, im going to check now
Old Jul 1, 2012 | 01:30 PM
deadstockkpomp's Avatar
You can't set different boost levels in the tune with just a MBC. If you get tuned with Tephra v7 and a BCS you can then set gear-dependant boost control.
So your saying i cant turn my boost down with my mbc and be safe? I was overboosting and turned down the boost, im cofused.
Old Jul 1, 2012 | 01:37 PM
Waldo's Avatar
He was saying that you cannot set different boost levels in different gears with just a MBC. Once you set the level with an MBC it will be constant in each gear.
Old Jul 1, 2012 | 01:40 PM
Waldo's Avatar
I just checked under my glovebox and everything looks factory, definitly no EMS unit there but i do see wires towards the front up behind a plastic plate.
Old Jul 1, 2012 | 01:48 PM
ToddRhodes's Avatar
Mine does the same thing - 22 psi in 2nd, 24 psi in 3rd and 4th. I had to back the MBC down quite a bit more than I thought I'd have to to get just 23 psi in 3rd and 4th. Haven't paid attention to what it is now in 2nd. I just chalked it up to increased load in 3rd and 4th making for slightly the slightly higher boost. My boost solenoid is completely unhooked, it's only running an MBC (tried two kinds, a Perrin inline and now a Grimspeed) Both perform exactly the same. Again, just try cranking it down a full turn to see if that gets you any lower boost in higher gears.
Old Jul 1, 2012 | 01:56 PM
Raptord's Avatar
One of the reasons I prefer ECU-controlled boost
Old Jul 1, 2012 | 02:43 PM
Waldo's Avatar
I have a Forge Motorsports one and it seems to only turn 180 degrees. All the other ones I have had in the past have turned 360 degrees. Is this true for the Forge unit or am I just an idiot that is too afraid of breaking something?
Old Jul 1, 2012 | 04:40 PM
silverIXMR's Avatar
maybe you have a 25lb wastegate actuator
Old Jul 1, 2012 | 05:34 PM
Waldo's Avatar
That was one thing that crossed my mind but in 1st and 2nd gear it only hits 20 psi.
Does anyone have the Instruction manuel for the Forge MBC that they could post here and or hook me up with?
Old Jul 1, 2012 | 06:10 PM
silverIXMR's Avatar
it wont necessarily make your boost exactly 25psi depending on how the preload is set. does it look stock? the forge mbc should turn 11 full rotations from - to +, got one in my hand
Old Jul 1, 2012 | 08:00 PM
Waldo's Avatar
Okay well then maybe i should try turning it with more force then.
Do you have the one with the little knob on the top?
Could you possibly post a picture of yours so i can compare?
Old Jul 2, 2012 | 03:35 AM
silverIXMR's Avatar
sorry i dont have a camera but if you google forge unos its the first one that comes up.. the one I have has the dog bone like top, not the flat one
Old Jul 6, 2012 | 12:44 AM
Waldo's Avatar
Okay cool, that's the same one I have as well. I'll have to check it out
HELPr
Apr 19, 2012 08:19 PM
mocohead
Nov 2, 2010 07:59 AM
otbEVO
Jul 6, 2009 08:11 PM
This_Guy777
Sep 25, 2008 03:32 AM
