Evo 8 not starting?
Old Jun 8, 2014 | 07:56 AM
Dirty Dave's Avatar
No didn't sell the car!!!! Lol. You know what I found???? The little wire that connects to the starter was not making a good connection. So pulled it off and squeezed the connector a little and put it back on. Since then haven't had one issue.
Old Jun 23, 2014 | 10:01 PM
BadassEvo8's Avatar
Just out of curiosity. I bought an Evo 8 with possibly a bad ignition switch. The key turns competently fine in all positions but to get it to turn on I have to push (really hard) In and up and turn all at the same time. So my only question is:
WHERE DO I FIND AN IGNITION SWITCH?
Old Jun 5, 2015 | 02:24 AM
coreymelton's Avatar
So did you find your ignition switch? I've been having this problem since I bought my car. Haven't bothered to try to fix it until it recently got so bad I could barely start my car. Turn the key, nothing would happen, everything would work. Had to push hard towards the steering column. So I took my ignition switch, loosened it, and turned it clockwise and now it works fine.
Old Feb 16, 2023 | 05:39 PM
WelDun1's Avatar
Solutions for almost every scenario
So I spent the last 2 weeks going through my entire Ignition/Starter system and I've pretty much solved the problem for every common scenario. ¹) If you are turning the key and you aren't hearing the starter click or w/e, the 1st place to look is the Ignition switch.By now everyone should know the problem with our cars ignition switch is very common. So rip the steering column panels off and check the single little screw that holds the switch in place. If it's loose, that could be your problem. Tighten that irritating turd up and see if it turns over.If not, remove the switch and see if it's worn out. Easy to determine, if the rectangular slot is worn into more of an oval shape, chances are you'll need a new one. But first, stick a screwdriver in the slot and attempt to start the car. If it starts, than the switch is your problem. I saw a post where the guy cuts a piece of tin into a long strip, folds it in half and sticks it into the slot to get rid of the slop & it seemed to work for him & it's a viable option if you're broke(if u own an Evo chances are high LoL), but if you can afford a new switch I recommend doing so! ²) if the car still doesn't start after checking out the switch, we will move on to the Starter Relay. It's the relay closest to the front in the skinny box under the hood.You can check if the relay is good by using a 9v battery and connecting one end of the relay to the Neg— and the other end to the Pos+ and listening for the 'click' sound. If the relay is good, you should check the battery terminal connection. One of the fuses on the battery terminal goes to the starter(ACD is the other if u have ACD).Ive seen threads dedicated to bypassing the Relay or allowing it to recieved 12v if for some reason it's not getting it. Best way to check is to use a voltmeter and check the small black wire connected to the spade on the starter. If it's getting 12V than that's not the problem. Next check the actual 12v power line to the Starter. It's the only other connection to the starter. Make sure the bolt is tight & check the voltage to it. If it's not getting 12v than there's a loose/bad connection from the starter to the fuse box. If it IS getting 12v than the next step is the Starter itself.³) If your starter has trouble in the Cold and works better after heating up, chances are that the brushes inside are getting gummed up and need to be replaced. When it's cold like anything becomes stiffer and when it warms up becomes more pliable which explains why it'll start once warm.You can either buy a new starter, which is going to cost you around $100-$250 & it's the best route if you can afford it. Or you can rebuild the starter for around $30-$40.You can buy the Mitsubishi Lancer Starter Rebuild Parts here. You most likely only need the brushes but I recommend replacing the solenoid as wellBrushes pn 5503063ASolenoid pn 66033392 So this pretty much covers every reason for the Evo not to start when we're talking Ignition/Starter issues. I hope this helps someone else figure out the problem faster than it took me. I had so much going on and so Lifetime to work on my car that I was pop starting my Evo for 2 weeks & had to leave it running LoL
lancer586
Lancer Troubleshooting
42
Apr 10, 2021 02:16 PM
Wmu240
Dec 18, 2015 10:18 AM
TreatsIX
Oct 24, 2015 03:20 PM
Wmu240
Sep 4, 2015 07:02 PM
MichyMY10RA
Jun 4, 2015 01:32 AM
