A/C compressor clutch engages when jumped
Old Jul 5, 2012 | 08:52 PM
ariasdejesus's Avatar
Hey, wondering if anyone might have any ideas on solutions. My compressor doesn't kick in unless jumped, I have checked all the relays check out. Bought the car a while back and recently decided to work on it. Hasn't worked on my possession.
Old Jul 6, 2012 | 01:21 AM
SW20Mike's Avatar
Veteran: Air Force
First you should take it to a reputable shop and have the Freon checked, you might be low or empty. If that checks good then possibly a bad pressure switch.
Old Jul 6, 2012 | 07:25 PM
Berts24's Avatar
prob. a bad clutch had isssues with mine replaced with a used one and has been working since
Old Jul 6, 2012 | 07:38 PM
barneyb's Avatar
The refrigerant cools and lubricates the compressor. If the refrigerant is low, the pressure switch shuts off the compressor clutch.
Old Jul 6, 2012 | 07:47 PM
IzzyRS's Avatar
easy test to see if its the freon level:just go get a can of the refrigirant from the auto parts store and add it to the car
Old Jul 6, 2012 | 08:32 PM
hatesposers's Avatar
OK, this is a BAD idea... While low frigerant levels will cause it to not work, high levels will break things.... EXPENSIVE THINGS... at AC shops, they call those "fill it yourself" kits "future compressor work in a can"
If you want to do it yourself, then first check your pressure levels with a guage kit... they are cheap.
It could be a number of things...
1) Low frigerant levels (it's not freon)
2) Bad relays
3) work clutch surface (there is a thread on checking the air gap)
4) Bad Hi/low switch.
It will be cheaper to take it to a shop and have them vacuum/fill your system than it will be for you to throw parts at it and see if it fixes it.
Most will do a diagnosis for free.
Old Jul 6, 2012 | 08:36 PM
Oh, side note...
I just went through a host of AC problems....
My frigerant levels were low... I had them vacuum the system down to nothing, and hold a vacuum there for 30 min. Then fill it to recomended capacity.
My AC would work for 5-15 min depending on the outside temp, then stop working... Turns out my clutch was so worn that even when the clutch would "click" and engage, there would not be enough clamping force (due to the wear), for it to fully engage and turn when the compressor got hot.
There is a shim kit to help with a worn clutch (there is a thread on this site)... but mine was so worn that I will eventually need a new assembly. I just pulled the shim out entirely to reduce the air gap, and will replace my clutch assembly when I have the money... With my temporary fix, my AC is blowing cold.
M-Ray90
Lancer Troubleshooting
Jan 29, 2021 02:04 PM
BrunoBoy650
Feb 18, 2015 01:37 PM
S3CR3T
Jun 14, 2013 06:15 PM
okevolutionVIII
Aug 27, 2012 01:48 PM
lucky_evo
Sep 1, 2010 07:54 PM
