woke up to a rough idle
Old Jul 14, 2012 | 11:12 AM
gomcar25's Avatar
https://www.youtube.com/watch?v=1dGD...e_gdata_player
Old Jul 14, 2012 | 11:16 AM
IamFredrik's Avatar
That sounds like a hole in the exhaust to me..what happens if you like put your foot, hand or towel into the pipe.. does the engine keep on idling at the same RPM or does it drop a bit or much?
If it idles at same rpm you got a hole.. if it dies / lost a lot of rpm its something else!
PFC McDonald's Avatar
Does it start up cold fine?
Old Jul 14, 2012 | 03:55 PM
Drill_Sergeant's Avatar
Veteran: Army
If you have the capabilities, hook evoscan up and log STFT. If you are getting zero feedback, you're o2 sensor is bad and I've seen that with a couple locals. Sudden death of the sensor
Old Jul 16, 2012 | 10:28 AM
gomcar25's Avatar
It fires up fine, but the second it turns over the idle drops and almost stalls just happened again. I had to give it a little throttle to keep it alive
Old Jul 30, 2012 | 05:42 PM
dr_latino999's Avatar
Veteran: Army
Did you ever solve this? I am having a similar problem, just not as lopey outside of the car. Woke up to it as well on the 23rd. Idle is only fluctuating 29 RPM back and forth according to datalogging from evo scan.
https://www.youtube.com/watch?v=JWVfdtDa41g
Old Jul 30, 2012 | 05:45 PM
boostedrb's Avatar
When this happened to me my IACV went bad
Old Jul 30, 2012 | 08:51 PM
gomcar25's Avatar
I got rid of my hks filter for a new clean k&n, cleaned the Maf and sprayed the throttle with the maf cleaner. Help out a lot. Next step is to take the throttle off and clean it fully. After I figure out why I snapped two belts in four hours. Unrelated issue.
Old Sep 1, 2012 | 09:13 AM
gomcar25's Avatar
changed plugs, and cleaned throttle didnt help.....
3gEclipseTurbo
19
Feb 3, 2011 04:29 PM
itzsteven
Dec 14, 2008 06:26 AM
Sk8boardIL
Jul 17, 2003 03:45 PM
