shifter on my evo is very stiff in every gear
Old Jul 10, 2012 | 04:53 PM
QUANLOCO's Avatar
I have just swapped out the Underhood bushings and it is still stiff going into every gear. I am just wondering if anyone has ever dealt with this. Thx
Old Jul 10, 2012 | 05:07 PM
lostsoulsevo's Avatar
transmission fluid low?
Old Jul 10, 2012 | 05:25 PM
xbattousai's Avatar
Same here I install mines few weeks ago, I just thought it was suppose to that way. Anyone care to chime in?
Old Jul 10, 2012 | 05:30 PM
QUANLOCO's Avatar
Not sure how to check that
Old Jul 10, 2012 | 05:53 PM
Berts24's Avatar
level the car off (perfect if you had a lift) then take off the filler plug on the trans. the fluid should be filled to the hole. I find that mine has good days and bad
Old Jul 10, 2012 | 07:36 PM
Chef-j's Avatar
Try change fluid. Idk what you running, i heard many 5spds owners are happy with amsoil or redline. If you have 6spds, i recommand castrol syntq.
Old Jul 10, 2012 | 07:53 PM
iitzbebo's Avatar
Has to be something other,then the Trans oil I jus got mine rebuilt and put in fresh oil and it still is hard..im thinking it might be the shifter cables
Old Jul 10, 2012 | 08:34 PM
ch53avitech's Avatar
I'm experiencing the same thing except only when going into 5th gear. I too have under-hood bushings, base bushings, and a short shifter.
Old Jul 10, 2012 | 09:23 PM
if you have any slop/movement in the under hood shifter bushng it will feel stiff to shift. what kind of bushings do you have. this is most common with sold metal bushings.
Old Jul 10, 2012 | 10:25 PM
QUANLOCO's Avatar
Can't remember name of company but they r brass. I just changed them today. I'm thinking it has to be the cable
Old Jul 10, 2012 | 11:00 PM
did you use the clip washer? or a twist pin tosecure it? make sure you didnt twist the cables when you put them on. that could possibly make it tighter
mmmantei
Lancer Tranny/Drivetrain Tech
Oct 11, 2014 09:55 AM
Piro Fyre
Oct 6, 2013 03:38 PM
5LEEPERISAH23I
13
Aug 10, 2013 10:55 AM
ElectricBlueIX
24
Mar 21, 2010 09:48 PM
dxbevo9
28
Jul 10, 2007 03:36 AM
