OverHeating
Old Jul 16, 2012 | 06:18 AM
Ministroker214's Avatar
this is the "temperature" when it sat for more then 12 hours over night, wondering if it really isnt even over heating, maybe just a messed up gauge, and how could i check?
Old Jul 16, 2012 | 09:41 AM
Can't get it into a shop til tomorrow, hopefully it's an easy fix
Old Jul 16, 2012 | 01:13 PM
gotonefinally's Avatar
Gauge looks stuck
Old Jul 16, 2012 | 01:44 PM
crazybaldhead's Avatar
Run a ground directly from the batt ground to the gauge ground. It's on the valve cover closest to the BOV. See if the stock gauge behaves normally. I'm wondering if your fan might be the thing making the noise.
Old Jul 16, 2012 | 01:58 PM
The noise has stopped, so it may have been a coincidence...but it's like stuck at quarter way when cold, then when warm (running temperature) its spiked to the H...I wonder if my system that is running off the battery has anything to do with it?
Old Jul 16, 2012 | 06:14 PM
EVO'D8's Avatar
This is an interesting post because my car is doing the samething, it's like I have to left off the acceleration peddle and then it goes back down to normal. Maybe check the water pump because I'm doing the samething with my car and the belts
Old Jul 17, 2012 | 04:25 AM
That is weird.. I'm bringing it to a shop this morning
Old Jul 17, 2012 | 06:27 AM
grillpt's Avatar
Not trying to stray away from the OP's issue, but is it overheating when you're boosting? If thats the case, your HG is toast.
OP, good luck with the shop. Hopefully they can resolve your issue for you.
Old Jul 17, 2012 | 07:11 AM
No, it will start to go up as I just let it sit there idle, I try to stay out of the turbo period when I was testing ye over heat...I feel like it may be just the gauge, but I will know shortly
Old Jul 17, 2012 | 07:54 AM
Thank god it was just a bad sensor, thank you guys for al your help, I'm glad you were all wrong! Haha
Old Aug 8, 2012 | 08:34 PM
Got_Boost's Avatar
I'm having I believe the same issue. Car temp is fine till you start boosting and it goes up. Slow down or let off gas and it slowly goes down. Is this what you had? If so how did you fix it? Parts o part numbers would be great. Thanks
Old Aug 12, 2012 | 08:47 AM
Got_Boost's Avatar
Anyone?
Old Aug 12, 2012 | 09:19 AM
bigben's Avatar
sensor that the ecu get it's readings from:
http://www.streettunedmotorsports.co...emp_sensor.htm
sensor that goes to the gauge:
http://www.streettunedmotorsports.co...uge_sensor.htm
With any of the oem parts on STM's site, you can add the parts to your cart. When you look in the cart, it will show you oem part #'s, in case you just wanna pick them up at a local dealer. Extremepsi is good for oem part # referencing as well.
Old Aug 12, 2012 | 02:32 PM
barneyb's Avatar
Watch to see if coolant is being pushed over to the jug and then onto the ground. If that happens and you know you have a working thermostat = HG.
Old Aug 12, 2012 | 08:37 PM
Got_Boost's Avatar
Thanks. Once I find the exact problem I'll post it up for future problems.
