where to route postive cable thru firewall?
Old Jul 16, 2012 | 04:47 PM
EVO8STI's Avatar
im putting a sub in my car and cant find a good placed to route the positive cable thru the firewall. id like it to go thru the firewall on the drive side. where has everyone routed their cables? i will also use the same spot to route my wideband and boost cables thru as well.
Old Jul 16, 2012 | 05:00 PM
PatricksEvilEvo's Avatar
I ran mine thru a hole behind the glove box.
Old Jul 16, 2012 | 07:18 PM
hatesposers's Avatar
I ran mine through the driver's side fender, then through a pass through below the A pillar in the gap between the fender and leading edge door, then through the driver's side scuff plates, behind the seat and into the trunk.
Old Jul 16, 2012 | 07:20 PM
GTijoejoe's Avatar
I too routed mine in the fender.. there is a grommet which goes inside the car... popped right in... than it runs down the center of the car as my amp is mounted to the back of the seats on the x-brace
Old Jul 16, 2012 | 07:21 PM
Revo15's Avatar
I seen this evo owner run his Under his car..Idk lol i think its zip tied on the brake lines..
Old Jul 16, 2012 | 07:27 PM
Originally Posted by revo15
i seen this evo owner run his under his car..idk lol i think its zip tied on the brake lines..
bad idea, bad idea, bad bad bad bad!!!!!!!
Old Jul 17, 2012 | 05:01 AM
boostedmkiii's Avatar
Same here.
Old Jul 17, 2012 | 05:11 AM
TommiM's Avatar
My 0 gauge cable fit through the grommet thats in the firewall behind the glovebox.
Old Jul 17, 2012 | 03:41 PM
EVO8STI's Avatar
well sounds like im doing the glove box thing. do the cables hide well when routed to the passenger side of the engine bay?
Old Jul 17, 2012 | 04:22 PM
The hole is about half way up the firewall so run it into the bay, then down and around the back of the engine, you can't really see mine and that's how I ran my boost gauge and battery wire.
Old Jul 18, 2012 | 03:05 PM
Tpatterson's Avatar
are you guys talking about the grommet that a harness runs through below the blower motor, right above where the carpet stops? That's the only rubber grommet that I can see. How did you guys get through it? I can't get the thing to budge, was gonna cut a small slit in it.
Old Jul 21, 2012 | 04:28 PM
EVO8STI's Avatar
yeah i cant seem to cut thru that 9 miles deep grommet, im afraid to force it and accidentally cut a wire or something.
JUS4SHO
11
Jun 29, 2015 01:47 PM
350EvoZ
Dec 20, 2014 09:28 AM
Boostagsr
Jun 21, 2013 09:04 AM
dacib
Apr 12, 2011 06:58 PM
mrfred
Jul 24, 2007 09:49 PM
