Evo FAIL AGAIN
Old Aug 1, 2012 | 09:24 PM
  #31
luis!'s Avatar
Originally Posted by EVOWRC111
Oil pump is seized, and the Gates belt is shredded.... I have picks but I'm gonna wait to post them. Its all up to MAP now. Here comes another 2 months of waiting.
Old Aug 1, 2012 | 09:37 PM
  #32
Teal2nnr's Avatar
So did you notice any alignment issues with the timeing belt before this happened?? or anything?
Old Aug 1, 2012 | 10:19 PM
  #33
flymx771's Avatar
Timing belt could have made the pump gears seize if it was set too tight. Does it have a stub shaft by chance?
Old Aug 1, 2012 | 10:40 PM
  #34
EVOWRC111's Avatar
It has the MAP BS delete so I believe it's a stub shaft. How can it make the pump gears seize? It was tight but not crazy tight.
Old Aug 1, 2012 | 10:41 PM
  #35
EVOWRC111's Avatar
Nope none.
Old Aug 1, 2012 | 11:51 PM
  #36
jeremy52048's Avatar
geez ouch.
Old Aug 2, 2012 | 10:44 AM
  #37
gpfury86's Avatar
Who timed the motor and built it into a long block, did u receive it as a built short block or long block from map?
Old Aug 2, 2012 | 11:02 AM
  #38
RallySport9's Avatar
LOL OUCH dont mean to laugh at you but that sucks.
Old Aug 2, 2012 | 11:10 AM
  #39
Boostin_AWD's Avatar
I had a new oem mitsu pump seize on me, luckily it was at an idle and everything was tight enough that my gates belt stopped it dead. Did you pull it and inspect the pump? There are a few things that could have happened. My personal experience, the main shaft on the drive gear did not receive lubrication quick enough and ended up seizing in the case. Another likely cause, the bolt backed out on the driven gear letting the stubby shaft drop and wedging the driven gear into the case.
Old Aug 12, 2012 | 02:34 PM
  #40
Teal2nnr's Avatar
any news??
Old Aug 14, 2012 | 09:48 AM
  #41
EVOWRC111's Avatar
any news??
Its being inspected
Old Aug 14, 2012 | 10:08 AM
  #42
wisniaPl's Avatar
Im on my 4th engine now...I know how you feel lol
Im afraid to drive it
all failures weren't my fault either who built it or just part failure
and what sucks is there is no warranty for built motors
Old Aug 14, 2012 | 10:17 AM
  #43
ikt's Avatar
ikt
take that **** somewhere else son!
Old Aug 14, 2012 | 11:32 AM
  #44
wisniaPl's Avatar
well seems like Buschur was the key
Old Aug 15, 2012 | 03:19 PM
  #45
Teal2nnr's Avatar
Although warranty isn't implied, any shop that wants to keep customers around should honer assembly error, and correct the problem at no cost.
Otherwise I’d start a **** storm and make sure everyone knew about it.
