Evo FAIL AGAIN
Old Jul 27, 2012 | 08:53 PM
EVOWRC111's Avatar
Evo FAIL AGAIN
FML!!!!!!
ok, so I posted on May 18th that I blew my engine at Button Willow raceway, well the new one didnt last long. This is my list of mods on the OEM motor when it blew the first time.
ARP Head studs
Grim Speed 3 port boost solenoid
Cat delete
Megan downpipe with HKS cat back
FP Black turbo
Megan O2 housing
Deatschwerks 1000cc injectors
255 Walbro
Upper and Lower AMS Intercooler pipes
Large front mount intercooler
272 Kelford cams
GS beehive valve spring w/Titanium retainers and valve seals
AEM intake
HKS none recalculate blow off valve
6 puck ACT clutch
Gates racing belts
Omni 4 Bar map sensor
All steel braided clutch lines with restrictor pill removed
So now I have a new MAPerformance stage 2 engine and also rebuilt my trans through Jacks Racing trans. My Gates racing belts were only used for 900 miles so I reused them. It ran a little over 400whp on Ca grade 91oct. The timing belt broke or the belt tensioner for the timing belt broke.........FUUUUUCKK!!!!!!!!! I cant win, I swear..... Come to find out the oil pump is lock up solid. Sending it back to MAP to be checked out.
MAP engine -
2.0 with 9:3.1 Weisco Pistons and Manley H-beam rods. All ARP studds Main and Head.
Old Jul 27, 2012 | 08:58 PM
evolutionxtac's Avatar
So who's your tuner?
Old Jul 27, 2012 | 08:59 PM
novem's Avatar
Do have a wide band? How much boost are you running a black on 91?
N
Old Jul 27, 2012 | 09:00 PM
Dirty Dave's Avatar
So how did the motor blow the first time at the track?
Old Jul 27, 2012 | 09:45 PM
sincitydagzr's Avatar
who installed the motor and who tuned the car? are in vegas or socal?
Old Jul 27, 2012 | 10:05 PM
EVOWRC111's Avatar
My tuner is Yimi sport in L.A.
Old Jul 27, 2012 | 10:14 PM
VQChris's Avatar
Damn bro that sucks. Have you contacted MAP?
Old Jul 28, 2012 | 12:14 AM
Tanro's Avatar
I don't get what boost pressure has to do with a t-belt failure.
Old Jul 28, 2012 | 12:29 AM
flymx771's Avatar
Me either..
Sounds like something went wrong with the timing belt install or you had a defective belt. Regardless, I know how you feel OP. I just spun a rod bearing on my 7,500 mile motor and am not looking forward to dishing out 2 grand next week.
Old Jul 28, 2012 | 09:46 AM
EVOWRC111's Avatar
I'm going to wait till I can inspect it more closely but if I feel that had to do with their balance shaft removal kit then yes, for sure their gonna hear from me. It's another possibility that the oil pump housing failed from the balance shaft being removed. When I was having the engine built I asked about any issues since they don't have anything backing the oil pump once like AMS does when the balance shafts are removed but they claimed to never have experienced an issue. Well, I will see soon and pics will be posted.
Old Jul 29, 2012 | 02:06 AM
Kelb's Avatar
mmmm this thread makes me shiver.
Old Jul 29, 2012 | 11:58 AM
EVOWRC111's Avatar
You should see my wallet, It shakes like Cali earthquakes.
Old Jul 29, 2012 | 12:02 PM
NOMIEZVR4's Avatar
keep us updated, I was thinking of getting MAP motor with the BS removed.
Old Jul 29, 2012 | 12:14 PM
Blue91lx's Avatar
I highly doubt it was an issue with the MAP BS delete kit that caused your issue. Are you 100% sure you tensioned the belt properly?
Old Jul 29, 2012 | 12:29 PM
Chef-j's Avatar
sorry but comment was funny and i felt same before with my previous car
