The first time my Evo has let me down....
Old Jul 31, 2012 | 11:43 AM
  #31
blknblubkrdude's Avatar
Strange... I just loaded up Evoscan and my MAP is reading -14psig with the engine off!
Old Jul 31, 2012 | 02:33 PM
  #32
nismo05's Avatar
What does it read with the engine on? If the reading never changes, it definitely needs replaced.
Old Jul 31, 2012 | 02:58 PM
  #33
That's the problem, I can't get it running to check the reading, as the only way it runs is pounding on the throttle- which will never result in a steady reading.
Old Jul 31, 2012 | 03:04 PM
  #34
hiboost2.0's Avatar
I'm really upset I saw this thread when I did. As I was reading I was thinking in my head it's more than likely the map sensor. I wish I was in time, but never the less good luck man.
Old Jul 31, 2012 | 04:28 PM
  #35
nismo05's Avatar
disconnect your map sensor and an intercooler hose and try starting your car. it should idle relatively fine if your map sensor is ok.
Old Aug 1, 2012 | 08:59 AM
  #36
I took the MAP sensor off and threw on the OEM one. Still no go. So I put the Omnipower back on.
After doing that I realized I had a DW300 fuel pump on the bench that was good.
When I pulled the fuel lines off of the module I was suprised there was no fuel pressure, as the guage was reading 40.
I went under the hood and flicked the gauge and sure enough, it was stuck.
This time I turn on evoscan and the MAP is reading -2.2psig with engine off, instead of the -14.3psig it read before.
I go to crank and it fires right up. It was a little rough and missing once in a while, but I let it warm up and it drives as good as ever...?
Old Aug 1, 2012 | 09:06 AM
  #37
tiggeryellow1's Avatar
Veteran: Army
Nicely Dun!
  #38
Ricoswave's Avatar
Edit.............sweet easy fix!
Old Aug 1, 2012 | 01:52 PM
  #39
wjamyers's Avatar
evom FTMFW!
Femi
AEM EMS
23
Apr 5, 2016 11:38 AM
TLeid91
Apr 4, 2016 07:43 AM
1badgsex
Jun 26, 2012 01:46 PM
Warrtalon
373
May 16, 2010 09:32 AM
scott88vr6
241
Apr 19, 2006 07:21 PM
