Throttle body shaft seal, Recommendations?
Old Aug 2, 2012 | 02:36 PM
kaonashi's Avatar
Can anyone recommend me a decent prices high quality shaft seal? I've read a few do not hold up as good as others. The car will be on 25psi + so I need one that won't fail anytime soon!
Old Aug 2, 2012 | 02:41 PM
grim~'s Avatar
http://www.streettunedmotorsports.co...haft_seals.htm
Old Aug 2, 2012 | 03:26 PM
TommiM's Avatar
^^ these.. The MIlspec shaft seals are awesome.
Old Aug 2, 2012 | 03:28 PM
03evo8racer's Avatar
I'd definitely go with the mil spec shaft seals. Great product and not expensive at all.
Old Aug 2, 2012 | 03:34 PM
kaonashi's Avatar
Awesome, it was this or STM's shaft seal. I need them overnight-ed either way.
Old Aug 2, 2012 | 04:44 PM
svt_lightning01's Avatar
Are your oem ones leaking? 90% do above 25 or so psi but some don't! Lol may as well leak test it at that psi and see?
Old Aug 2, 2012 | 04:50 PM
TommiM's Avatar
My oem ones started leaking at 11-13 psi!!! Went with the Mil Spec ones and they havent leaked yet, and I regularly boost leak test to 30 psi.
Old Aug 2, 2012 | 04:56 PM
Wow! Lol my oem ones haven't leak yet knock on wood !!! Lol idk how.
Old Aug 2, 2012 | 05:02 PM
kaonashi's Avatar
The car has 99,9xx miles on it, & my idles acting funky, I'm assuming its thus because I've replace every other seal/gasket that could leak. Fingers crossed!
What company overnights?
Old Aug 2, 2012 | 05:06 PM
What do you mean funny idle? If they are leaking I would certainly replace but there's no guarantee that is the cure for the idle. What about iac, egr, etc
Old Aug 2, 2012 | 05:24 PM
kaonashi's Avatar
Just deleted egr, double checked the block off plate. No leaking. All vacuum lines replaced today. How do u suggest i check iac? The plugs are new aswell
Old Aug 2, 2012 | 05:36 PM
awdordie's Avatar
i would check it in evoscan if you have it.
on the shaft seals i would get mil spec as well. they are a pain to install if you arent careful they bend easily and are screwed.
Old Aug 2, 2012 | 05:45 PM
kaonashi's Avatar
Ahh I'll find a write up on the install, Yeah I have evoscan my harddrive crashed so I'm using my phone until the new harddrive comes in.
Old Aug 2, 2012 | 05:53 PM
If it were me being they are decently inexpensive I would order two sets so you can mess up a set if it happens and you have others readily available. I also had an idle problem awhile back and it turned out being the egr I think. I checked my iac by removing it from the car and checking the pins for resistance with a multimeter you can also unbolt it leave it plugged in the sensor and turn the key to on I believe it is supposed to click and search in and out for idle position.
bigben's Avatar
+1 for Milspec, but I doubt you're going to get them overnighted from anywhere.
