motor mounts DD
Old Aug 16, 2012 | 01:57 PM
elim0's Avatar
motor mounts DD
hey guys, just been through a few threads about motor mounts > torque damper to minimize movement in engine. help shifting, smoother and higher rpm shifting.
seems like a lot of people who have upgraded have done their front motor mount, usually with a blox or something. i was just wondering is it suitable for DD or should a bushing press one just be purchased ?? what are your thoughts ? i already have cams and the car vibrates a bit anyway
any feedback or experience would be much appreciated !
thanks in advance !
Old Aug 16, 2012 | 02:12 PM
okevolutionVIII's Avatar
I personally just use a Blox front mount but I would imagine that replacing just the driver and passenger side mounts would be the best DD setup. The Blox mounts can be found used for around $45 and just swap them out rather than having the hassle of pressing bushings in/out plus saves a little weight.
Old Aug 16, 2012 | 02:17 PM
CurseDSM's Avatar
Whats wrong with stock ones?
Old Aug 16, 2012 | 06:18 PM
abazaba410's Avatar
x2. I replaced it on my 03 a few years ago and not sure if I noticed a big deal. cant recall though
Old Aug 16, 2012 | 06:38 PM
CurseDSM's Avatar
You go fully polly you will noticed a huge difference being you will feel every bit of the motor when it moves.
Old Aug 16, 2012 | 06:49 PM
TheBoz's Avatar
just do a front roll stop, and leave the rest stock.
Old Aug 16, 2012 | 09:12 PM
adriano_917's Avatar
This is how I have it, only the front agency poly mount and it feels great. Back when I had my Srt-4 I had the engine poly mounts and the tranny was a solid mount and the vibration was horrible for DD.
Old Aug 17, 2012 | 01:10 AM
elim0's Avatar
soo do the cam gear side and tran side (left right) ones and that would be the best for DD and leave front and rear one stock?
if the front one isnt too bad i might just order a blox or agency racing, unless anyone else can recommend a better one ?? cusco or something? .. as i heard the front one is cheap and can be done very easily at home
thanks for the help guys appreciate it !
Old Aug 17, 2012 | 01:22 AM
MR. EVO MR's Avatar
I did the blox front motor mount.
One of the best mods to date!
Old Aug 17, 2012 | 09:52 PM
Rmeister007's Avatar
Based off my research, the front MM is all you need to do for a DD. you'll feel the vibration for the first 1000 miles or so until the bushings break in and then you wont even notice it. Just don't do the rear mount!!! If u do, it'll be all hell!!!!! Unless it gets your gf horny....then do whatever u want. Lol!
Old Aug 17, 2012 | 09:59 PM
sujinX's Avatar
i have front only on my DD evo. its nice, dont really notice much.
i had full race mounts on my previous race/dd car. everything shook. like sitting in a vibrator lol.
Old Aug 17, 2012 | 11:20 PM
elim0's Avatar
http://www.ebay.com.au/itm/TORQUE-SO...item2c611b3ab5
http://www.ebay.com.au/itm/BLOX-FRON...item3f1041e169
ive gone through a few threads and some say as you guys are saying that the front one is all thats needed and will be sufficient although some people have said get the front, tranny, cam gear one at a lower durameter
which out of these would you consider for a DD .. the torque solutions one is rated 75A and i think the Blox is 90 ??
Old Aug 18, 2012 | 03:25 AM
jameelrose's Avatar
This one of those questions where the answers will always be highly relative. That's like asking how loud is a _______ cat back. It's all in perception. I would do them in stages until you get the balance that you are comfortable with. Front first. Sides next then rear last. The rear is the one that will make your life most miserable.
Old Aug 18, 2012 | 11:20 AM
elim0's Avatar
true. i guess i will go with the front torque solution as its rated lower at 75a and see how i go from there...............
Old Aug 19, 2012 | 12:02 AM
420a-t's Avatar
Ive done the front mount with the rest all stock, and it was all good wasnt really any different besides helping with shifting.
My stock rear mount was shot, so I decided to upgrade it as well. Shouldnt have done it lol.
It would be fine if it was a track only car, but its too much right now. granted, I only have 100 miles on the front mount and about 10 on the rear mount, but its pretty bad at idle. The rest of the time its fine
