How to tell if you have cams?
Old Aug 21, 2012 | 06:30 PM
steven121's Avatar
Bought my Evo 2 months ago and not sure if it has cams, it doesn't make the lope sound but is there a way to tell the difference between stock cams and aftermarket looking to eventually upgrade to 272s but want to verify before I start replacing parts. My motor came with an Evo 9 turbo so I'm not sure if the owner put them on or not "bought from a private dealer"
Old Aug 21, 2012 | 06:34 PM
EV0L-IX-MR's Avatar
Usually you can tell by the sound. But worst case pull your valve cover off
Old Aug 21, 2012 | 06:54 PM
svt_lightning01's Avatar
I had hks 280 cams and my car idled like stock when I got it so I would pull the valve cover
Old Aug 21, 2012 | 07:01 PM
sho669's Avatar
Crank your engine, if it starts and runs you have cams in there.
If you pass this test you can move on to stage 2...
Pull you valve cover and check for numbers to verify if your cams are aftermarket or not.
Hopefully the cam gods have blessed you with some aftermarket goodness!
Old Aug 21, 2012 | 09:23 PM
Thore's Avatar
and hope to god they didn't replace the cams with https://www.evolutionm.net/forums/ev...-obx-cams.html
Old Aug 21, 2012 | 09:35 PM
black_beauty's Avatar
I had HKS 272's and didnt know it til I pulled the valve cover off to powdercoat it. Doesn't take long to look. Hopefully you find a good surprise lol
Old Aug 21, 2012 | 11:10 PM
Spins_All_4's Avatar
Heres a pic of HKS 280s i have in currently.. but am replacing them with new GSC S3s so they will be for sale if you find out that you have stock cams
Attached Thumbnails How to tell if you have cams?-262025_195399513843466_1050031_n.jpg
Old Aug 22, 2012 | 05:25 AM
PatricksEvilEvo's Avatar
How about bottom end? Is there a way to inspect to see if it's stock bore, rods, pistons and bearings by pulling the oil pan and using a borescope?
Old Aug 22, 2012 | 05:46 AM
4G63 DSM's Avatar
I would say, first, by sound. Second, like others said, remove the valve cover to check. Also, you can sometimes see from removing the oil cap and peeking in with a flashlight (and if you know what you're looking for).
Yes, absolutely. It's usually pretty easy to tell if the internals are aftermarket at least.
Old Aug 22, 2012 | 05:54 AM
Alright cool, I'm finally putting my dd on the road so I can inspect. I'm making too much power for my mods lol. Too much torque, I'd like to know what it has before getting my E85 tune. I've dd'd this Evo for 4 years now "stock", it'll be funny if it turns out to have a 2.4L or something LOL. I didn't know it had a 9 motor and turbo until I took it to STM for a new tcase about a year ago before starting my mods.
Old Aug 22, 2012 | 10:16 AM
steven121's Avatar
Thanks I never owned an Evo so I don't know how they sound stock. I'll look later this week
Old Aug 22, 2012 | 10:22 AM
Mistaken's Avatar
Hope Christmas comes early!
Old Aug 22, 2012 | 11:00 AM
evodriver49's Avatar
your car have a boost gauge? stock evos will idle at about -20 vacuum on the gauge and with cams -10 to -15
Old Aug 22, 2012 | 11:17 AM
TurboTal's Avatar
most cams are marked. pull the valve cover off and look for brand names, and serial numbers, then search.
Old Aug 22, 2012 | 10:56 PM
evo_eddy619's Avatar
I just bought my evo 8. the previous owner said it got a hks 272 cams in it and gears. i guess i will find that out and add that task this weekend after i changed all the fluids.
