Exedy Twin...already slipping!!
Old Sep 6, 2012 | 08:37 PM
vtec lolz's Avatar
Thumbs down Exedy Twin...already slipping!!
found out the issue!
Old Sep 6, 2012 | 10:55 PM
Piro Fyre's Avatar
Do you have the SD version or HD? If it's SD, it can only hold 430ft-lbs and you are a little beyond that limit. If HD, then you might have slipped the clutch really bad at launch.
Old Sep 6, 2012 | 11:12 PM
evo8dreamcar's Avatar
Do you have a clutch stop? Mine was slipping and the clutch stock was to tight so i adjusted that and it worked good as new.
Old Sep 6, 2012 | 11:50 PM
brakeboost980's Avatar
Had a cusco in mine and it went On me Pretty fast as well.I didnt even botherurebuilding it just went with a competition stage 2 the new version and it rated for 500 tq!!Love it .P
Old Sep 8, 2012 | 02:41 PM
ctfpevoVIII's Avatar
I have a hks pro twin disk and only got about 12,000 miles out of it, just had the the cluth done with a rebuild kit for the hks pro twin disk. I don't know why it went so quick either I only have about a dozen hard launches on it?
Old Sep 8, 2012 | 03:56 PM
bigben's Avatar
The only downside of having a twin is their mileage. I drive right around 20k miles a year, and I don't foresee me being a fan of dropping the tranny once a year or more.
Old Sep 9, 2012 | 10:39 AM
JDMEVOLEX's Avatar
well Exedy redesigned their twin disk. so it might be that your using the previous twin disk. I just put a twin disk HD in my car never had a issue so far.
Old Sep 9, 2012 | 10:57 AM
Pure EvoIX's Avatar
I track the crap out of my car. I would say 30k total miles with 15 hard track days. And it is still working. Maybe all it needs is adjusting the engagement point.
Old Sep 9, 2012 | 11:20 AM
There just really made for racing ,as a daily they suck.I just had no luck with mine.
Old Sep 9, 2012 | 01:41 PM
xRoguex's Avatar
What the?
The exedy twin HD is the universally accepted best DD'ing clutch for the mild/moderate built evo....
Ive put a good 18-20k on mine and its still kickin.. and this includes going to track from time to time.
Old Sep 9, 2012 | 04:02 PM
Sure it was all that noise and slipping to take off .lol..You should drive a comp stage 2 hd then report back .
Old Sep 9, 2012 | 09:40 PM
xRoguex's Avatar
What a single disk clutch that locks you out at 8500 and has a tq limit of 425 -- no thanks.
Id shread that clutch in one track day.
The exedy twin HD is in a class above your suggested comp clutch...
Old Sep 10, 2012 | 12:57 PM
There's no lock out with the comp stage 2 hd.Here's the proof read this thread and watch the vid!
https://www.evolutionm.net/forums/ve...-alt-hdss.html
Old Sep 10, 2012 | 01:46 PM
deylag's Avatar
I have an Exedy HD and I have put 6k miles on it. Its not slipping at all.
Did you try the fifth gear test to confirm its slipping?
Old Sep 10, 2012 | 09:11 PM
xRoguex's Avatar
still only rated at 450 vs 535 -- and no single will ever shift as fast as a twin.
In my logs my shifts are .27-.29 without NLTS
