shaking metal sounds coming from car when driving?
hey guys my car makes this weird sound almost like metal shaking under my car. i thought it might be a heat shield but i don't have any on the exhaust. any insight please help
thank u
-Chris
thank u
-Chris
Tranny, transfer case, driveshaft, clutch, exhaust. With your info, those are your choices.
You should pinpoint a section that the noise is coming from. I.e. get under the car while its on. And what your car is doing when you hear that sound.
the only problem with that is i only hear that sound when im driving slow n it comes and goes its not a continuous sound. another thing is in the morning when i start my car it makes a really loud rattling noise as my rpms come down to idle.
Does the sound go away when you press the clutch? Or does pressing the clutch change the sound? Could be your throwout bearing.
yea bc it only makes the sound driving except when i first start it up when its cold n it goes away once the rpms drop, it lasts about 5 seconds when i start it up cold
From: Driving ten under in the passing lane, right turn signal on at all times.
I had something like that happen once. Turned out to be an exhaust hanger pulling loose.
I used a hose clamp to keep it from getting worse, then took to a muffler shop the next morning.
$15.00, 20 minutes, problem fixed.
anjapower
50
Feb 15, 2015 04:39 PM
