leaky ACD pump line
Old Sep 11, 2012 | 09:23 AM
Bignel00's Avatar
leaky ACD pump line
Hello! I just finished putting my evo 8 together after crashing into a curb ( due to bad weather) I noticed the other day a small amount of oil on my driveway. After going through the all the fluids i noticed that one of my ACD pump lines is leaking(Under radiator support . Ive looked at Mitsubishiparts.net for a replacement line. I cant find this anywhere online. Any ideas on repairing the leaky line ( never done one before) or is there a way to just eliminate the ACD pump system (with out changing the transfer case)
Old Sep 11, 2012 | 06:00 PM
TommiM's Avatar
I would see if you can find exactly where its leaking out of. Is it leaking because of a damaged line, or is it leaking through a connection? The acd line is pretty much a one piece spider web of hard line, and unless you have the engine out I hear it can suck to replace. You also have your powersteering cooler lines running near that area so I would verify it is indeed acd and not power steering. That line is much easier to replace, hell I got a spare one of those you can have if you end up needing it-- just pay shipping.
Old Sep 12, 2012 | 01:35 PM
EVO8emUp's Avatar
You should be able to get a replacement line. There are a few parts that are not listed on the site. Make sure it isn't the fitting located behind the bumper cover.
06redrocket
Nov 18, 2013 02:32 PM
blackandredgts
Apr 28, 2013 02:26 PM
MarylandEvo
31
Apr 16, 2013 12:06 PM
Trever007
Jul 15, 2011 11:15 PM
