***Evo VIII head gasket***
Old Sep 13, 2012 | 03:22 PM
JHS VIII's Avatar
Hey guys,
The head gasket in my evo 8 is starting to go. I have a garage that is going to replace the gasket for me.
Is there anything else you guys would recommend me doing while i am getting the head gasket replaced as well??
Cheers
Old Sep 13, 2012 | 03:28 PM
SilverShadow03's Avatar
ARP head studs
Have you done your timing belt, water pump, tensioners etc??
Cams? Cam Gears?
Old Sep 13, 2012 | 03:35 PM
JHS VIII's Avatar
Originally Posted by SilverShadow03
ARP head studs
Cams? Cam Gears?
I've heard a lot of people to put in ARP head studs but may i ask you why?
The timing belt was done however the water pump was not changed nor the tensioners?
I think i won't upgrade the cams just yet, i was thinking to in the future though.
Old Sep 13, 2012 | 04:00 PM
djdnav's Avatar
Head studs keep your head gasket from blowing from high boost. If there's any possibility you'll do cams in the future, just do it now. Why would you change the timing belt and nothing else? That's not good thinking.
Old Sep 13, 2012 | 04:05 PM
+1
Get back in there and take care of the full timing belt service. Just not good thinking to only do the timing belt.
If cams are in your budget, now would be a good time to do this along with cam gears...
You and/or the shop are probably already doing this but don't forget about a new exhaust gasket and new intake gasket.
Old Sep 14, 2012 | 05:39 AM
djdnav's Avatar
Unless You're planning on making super huge power, I would say cam gears are just for looks. Met people that have them leave the setting at zero anyway.
Old Sep 14, 2012 | 05:46 AM
mmmmbst's Avatar
Veteran: Air Force
Timing belt, tensioner, water pump and ARP head studs. Preventative maintenance and stronger parts give you peace of mind.
Old Sep 14, 2012 | 08:38 AM
ChUt26's Avatar
This. If your tbelt breaks or the tensioner gives out and your timing belt jumps you run the risk of blowing up your entire motor.
Waterpump because it is right there, and spend the couple bucks now while you won't have to pay for the labor rate down the road if it gives out.
EVO 4 life
Jun 29, 2016 08:28 PM
sammiek513
Lancer How Tos / Installations
Jun 12, 2016 10:22 PM
kinein
41
Mar 11, 2015 07:59 AM
GTijoejoe
Oct 3, 2012 10:09 AM
memphis raynes
Jul 7, 2012 12:44 PM
