idle issue
Old Sep 19, 2012 | 12:15 PM
Evolution8.5's Avatar
idle issue
lately after high load situations like launching or long pulls in peak boost the car doesnt like to idel after the car will hop from 500-1000 rpm for like 30 sec to a min if i give it a quick rev it will usually smooth back out any ideas as to what this could be mods are turbo back intake mbc bigger front mount
Old Sep 19, 2012 | 11:42 PM
vaflyboi757's Avatar
I had a similar issue before but it was after I overboosted. Is the car tuned, are the plugs gapped to far?
Old Sep 20, 2012 | 08:36 AM
car has a base map in it. i dont think im over boosting the car peaks at 21-22 psi and tapers off to 18-19psi. last i checked the plugs were good they were gapped to .020 and i feel like it isnt a plug issue because it doesnt break up any other time only at idel and icant seem to find any vacume leaks
Old Sep 20, 2012 | 12:25 PM
signalmotors's Avatar
Does it idle rough after boost?
Old Sep 20, 2012 | 02:02 PM
ya thats when it happens but its only if im in boost for a long period of time
Old Sep 20, 2012 | 04:52 PM
Spoolin63's Avatar
Sounds like it could be plug related. Thats a tight gap on the plugs. Im assuming you have a factory 8 bov?
Old Sep 20, 2012 | 08:00 PM
Had a couple of evos i worked on had problems with the egr valve solenoid. it would stick after boost. Cause a rough idle after boost. The solenoid is in the back below the intake manifold. I would check that.
bryanlo
10
Apr 9, 2014 10:40 PM
bboylegit
Jun 17, 2013 12:38 PM
DouggieVee
Mitsubishi TC-SST Discussion
25
Mar 20, 2013 05:02 AM
iAMgAWD
Feb 11, 2013 11:33 AM
Alkaedas_Inc
Dec 30, 2012 01:47 AM
