Quick question on battery terminal
Old Sep 27, 2012 | 02:05 AM
lalu's Avatar
Hi. My positive battery terminal is goosed. The stealership here loves to rip my wallet off. I have in hand a heavy duty Coleman MARINE grade terminal from ACE Hardware. The package says...'Marine grade batteries and marine battery cables 6 and 12 volt only'. Would that be OK for my evo? The word marine got me thinking...Cheers in advance
Old Sep 27, 2012 | 02:16 AM
Live4Redline's Avatar
Marine just means its more anti-corrosive then normal which is a good thing. It'll work perfectly fine for your 12v battery.
Just be carefull when working with or around the battery. Dry and wet battery acid is dangerous and can be flamible. Clean everything well or wear gloves if needed.
Old Sep 27, 2012 | 02:29 AM
lalu's Avatar
Love to hear that. Excellent. I'll take extra precaution when dealing with the stuff, thanks. Sorry one more little thing, the terminal does not have a '+' sign stamped on it but got a word 'P' instead which I assume as 'Positive'? Also does it matter if the other negative terminal (brass) isn't a Marine type?
Old Sep 27, 2012 | 05:22 AM
It does not matter, can have two negatives, two positives one marine and one not. Will make no difference other then maybe confusing you the next time you replace the battery. So long as both terminals have a good connection you will be fine.
Old Sep 27, 2012 | 05:52 PM
lalu's Avatar
That clears everything. Thank you very much! What a great site.
lbwilliams44
Jul 6, 2020 03:32 AM
tim85851
68
Aug 15, 2018 08:43 AM
Nevaeh
29
Mar 20, 2010 12:19 PM
WhiteGTS18
Lancer Engine Tech
May 9, 2009 08:13 AM
JeffR116
May 23, 2006 08:04 PM
