Boost leak testing
Old Oct 1, 2012 | 08:20 PM
zenoise's Avatar
Boost leak testing
So i just searched on here for almost an hour and found nothing. I was looking at at a thread and saw that a few guys were saying that upon doing a boost leak check a slow boost drop is normal. Is this? they said that if you put 30 psi in it, its normal to lose pressure in 60 seconds or so. When I have done my boost leak tests mine does this. I put about 30 psi and it slowly drops to 0 and id say it takes about a minute to two minutes. I have sprayed down everything and found no leaks. and boost to where i am supposed.
It would make me feel alot better to know this is normal. So basically you wont hold 30psi for good. It will drop out slowly from what I understand. Is this correct
Thank you.
Old Oct 1, 2012 | 09:43 PM
600RR's Avatar
Yes this is normal
Old Oct 2, 2012 | 06:26 AM
WikdEvo's Avatar
If you are putting 30# through the system and you can't physically hear the leak, i'm sure that you are fine.
Old Oct 18, 2012 | 03:50 PM
80210's Avatar
You should be just fine with this it will taper down and eventually loose pressure
1fast97gsx
May 1, 2014 09:52 PM
WORD
North Texas Evo Club (NTEC)
16
Oct 29, 2012 09:06 AM
KJS
Mar 12, 2012 05:17 PM
Clipse3GT
18
Dec 16, 2009 02:48 PM
Svendiesel
Nov 15, 2009 11:07 PM
