Boost drop off at higher rpms?
Stock 05 turbo, full bolt ons and hks 272 cams. The car will hit 25 psi and slowly drop down to about 20-21 by redline in higher gears. No boost leaks to just under 20 psi but after that the tester blows off. Is this an indication of a leak at higher levels or more the stock turbo running out of steam? I don't have too much experience with these things so I don't want to be chasing my tail if it's just a turbo issue. Thanks.
Get a MBC that will help some but you will still taper. Maybe get a new wastegate. You will probably still taper some but with both of those I think you will see the results you want.
