boost leak or BOV problem?
Old Oct 25, 2011 | 10:32 AM
taylorgang's Avatar
I can't get boost to go above 29 psi, and it drops off to about 25 psi by 6k and 21 psi by 7k
I have a hallman MBC so I believe that is normal taper... but the reason the boost won't go past 29 psi is because of a boost leak, right?
I have a synapse synchronic DV if that helps
edit : I'm doing a boost leak test tomorrow, just want to know if it IS a boost leak that causes the boost not to go higher than 29 psi
Old Oct 25, 2011 | 11:26 AM
06RedRalli's Avatar
What size wastegate?
Old Oct 25, 2011 | 03:23 PM
taylorgang's Avatar
Stock wastegate
Old Oct 25, 2011 | 03:36 PM
06RedRalli's Avatar
Get a higher psi wastegate. It'll allow you to run the higher boost. You've maxed out the hallman. Just make sure to turn down the boost controller when you get the new wastegate. I'd recommended a 25 psi since you're looking to run over that daily.
Old Oct 25, 2011 | 05:52 PM
Ev0ikon's Avatar
Is it tuned for that boost? Stock turbo? 21PSI by 7K RPM is all stock turbo could do. What gear was it when you got 29 PSI?
Old Oct 25, 2011 | 10:02 PM
taylorgang's Avatar
tuning it on e85 right now stock turbo running 29 psi in 3rd gear
Old Oct 26, 2011 | 11:14 AM
taylorgang's Avatar
Switched out the hallman with a buschur mbc and it still wouldn't go above 29 psi... rules out the mbc.
I don't think its the wastegate... people have hit 30+ psi on stock wastegate haven't they?
Maybe my boost gauge is off a couple psi and its really hitting 30ish psi rather than 28-29 psi
Doing a boost leak test today and will post an update.
Old Oct 26, 2011 | 11:49 AM
Broham's Avatar
it's your wastegate. I have a friend who couldn't hold it or get it there also, with the wastegate. Also, make sure your throttle body shaft seals aren't leaking. That is the sneaky boost leak that robs you and you don't know
Old Oct 26, 2011 | 04:53 PM
taylorgang's Avatar
Just an update for everyone
There are no noticeable boost leaks on the car
Turns out my gauge was off by about 1 psi, so it was really hitting 30, not 29.
SOLUTION: I added preload to the DV, connected both ports A and B and was able to turn the boost higher. Some of my partial throttle flutter went away too
TariqEvo
Aug 22, 2017 11:38 AM
LSs1Power
Apr 29, 2017 01:08 AM
nor11384
Jan 17, 2016 07:24 AM
Carter19
11
Apr 30, 2010 08:32 PM
2003raptor
27
Mar 19, 2008 08:52 PM
