Very hard to cold start on E85
Old Nov 14, 2012 | 03:29 PM
  #31
TheBoz's Avatar
Here is how you car should start in the cold weather. It is all about the tune. I know you are on a stock ecu, but if a car on an AEM EMS can start that fast a stock ecu sure as hell can.
Here is another one.
Old Nov 15, 2012 | 09:13 AM
  #32
10isace's Avatar
Originally Posted by nic411
alright, i don't have it bookmarked on my laptop, but here are the settings that i have on my car. ill do some steps just in case you don't know where to go.
1. expand "fuel"
2. check the box for Cranking Enrichment IPW adder (main). to be able to click on mine i had to go to file/options/user level, and change it to advanced.
3. change the inputs to the following using alt+] and alt+[
-32 360.0
-18 240.0
-8 120.0
7 60.0
20 16.0
34 7.0
50 3.5
77 1.5
82 1.5
the thread that i used to get these settings also had changes for battery voltage and fuel enrichment, but changing the IPW is all i did and it's worked great for me. i was considering going to 91oct for the winter, but theres no way i could after using the e85. so im glad this has worked out.
i think i said earlier in the thread that these changes also helped me with my warm start issue. i was having a problem if i turned the car off for 10-20 minutes, i would have a hard time getting it started again. give it a try and let me know how it works out!
Thanks!!! I put mine to these settings and it starts much better in the cold. It'll take one or two starts
Old Nov 15, 2012 | 09:23 AM
  #33
teamrevjohn's Avatar
Same thing happens to my car, how much power are you making on e85 if you don't mind me asking?
Old Nov 16, 2012 | 08:21 AM
  #34
nic411's Avatar
Good to hear it worked. I know for me there is a 70hp/80tq difference between my 91 oct and e85 tune, so I really didn't want to switch to pump all winter...lol
Old Nov 16, 2012 | 12:22 PM
  #35
jdmwiseman88's Avatar
what spark plugs are you running
Old Nov 16, 2012 | 01:08 PM
  #36
10isace's Avatar
I run NGK BR7ES. What's everyone else running?
Old Nov 16, 2012 | 01:36 PM
  #37
nic411's Avatar
I'm just running whatever the stock plugs are. Been a while since I replaced them and forget the number.
turbotaloon95
E85 / Ethanol
14
May 7, 2019 03:52 PM
russ72
Nov 3, 2014 11:11 AM
10isace
E85 / Ethanol
Mar 20, 2013 06:31 PM
Anubis18
Nov 19, 2012 11:38 AM
evil_eagle
AEM EMS
72
Dec 15, 2011 02:18 AM
