Hallman mbc
Old Oct 11, 2012 | 04:39 PM
steven121's Avatar
Hallman mbc
Can I remove the solenoid from the ecu or just cap it off?
Old Oct 11, 2012 | 10:43 PM
dkslvr06evo's Avatar
https://www.evolutionm.net/forums/ev...vo-rx-pro.html
https://www.evolutionm.net/forums/ev...r-install.html
That should help out
Old Oct 11, 2012 | 11:26 PM
llDemonll's Avatar
leave the solenoid plugged in. cap both ports
Old Oct 13, 2012 | 11:14 PM
Make sure you also use new Vac line with no pills when you switch to the MBC
Old Oct 14, 2012 | 11:39 AM
Boosted Tuning's Avatar
You can only remove the solenoid if you have ECUFlash so you can disable the CEL.
Old Oct 14, 2012 | 08:39 PM
steven121's Avatar
Well I figured out how to install it, I have ecu flash but not the aem wideband for tuning. Your suppose to leave the intake line on the solenoid to keep the ecu from tripping. But it's so much better the spool up is crazy fast and I am more comfortable tuning with a controller vs the ecu controlled boost. I would reccomend this to everyone.
I have the hallman pro boost controller.
Future note I drilled a hole in a clamp, bolted the mbc on the clamp and wrapped it around my intercooler piping for easy access it doesn't look to bad to be honest
Old Oct 14, 2012 | 08:48 PM
You dont have to leave that line on.
kpt6
Apr 17, 2013 01:12 AM
zasboy
25
Oct 14, 2012 12:44 PM
