Looking for a high flow cat....
First off I want to mention that I live in CA
I've been having a lot of issues this past year with local PD about my IX so I've been working on going stealth. I already put on a stealth TBE and took off the window tints and removed the oem wing. My problem now is I have to get a smog check and I still have a test pipe. I searched but didn't come up with anything good. Can someone please suggest a good high flow cat.
Thanks
Thanks
I have an AMS high flow cat on my X. It actually passed the CA tail pipe sniffer smog test. I failed the visual part of the test, but at least I'm not polluting the environment.
I did a smog check in CA before I moved to NM and that's how I got my results. The funny part is out here in NM you can pass a smog test with a test pipe. All they do out here is test the OBD2 for codes and kick the tires.
http://www.maperformance.com/works-e...9-140.300.html
Also ultimate racing they offers high flow cat looks like OEM. But i don't recommand this company tho.
Make sure get a metallic core.
Edit: DIdn't realize this thread is from month ago.
04tarmacEVO
14
Sep 3, 2004 01:49 PM
