Best reliability mods?
Old Oct 25, 2012 | 07:33 PM
kyoo's Avatar
Originally Posted by jeremy52048
what im saying about a built trans is it if it is built well , and is Daily driven will it make it last longer ? since its built for a beating right? so babying it must make it last longer then a stock should.
stock is good for like.. 350-400lb ft or something like that? idk
Old Oct 25, 2012 | 07:35 PM
adriano_917's Avatar
In a way! Yes, but you need to do regular maintenance. Now if you dont make crazy hp or abuse it the stock one should hold fine. If youre going to abuse it and make alot of power then yeah built it just like an engine making a lot of power. But for daily driving and occasional drag racing you dont really need too, if you know what youre doing!
Old Oct 25, 2012 | 08:12 PM
jeremy52048's Avatar
yeah i updated it. everything does depend on the power but for this thread im saying the car is stock besides bolt ons. Religious maintenance is a must
Old Oct 25, 2012 | 09:37 PM
kyoo's Avatar
^ in that case, I drive my evo fairly often with shep built trans and it is perfect - a little notchy in cold weather though. i pretty much change the trans and t-case once every 5k miles or something
Old Oct 25, 2012 | 09:50 PM
nightwalker's Avatar
Maintenance is key. My '03 has 206,000 miles and making 370 hp on pump.
Old Oct 25, 2012 | 10:02 PM
luis!'s Avatar
squash air freshener. .
Old Oct 26, 2012 | 12:11 PM
wow now thats good im at 104xxx these cars are just as reliable as any car ive owned. absolutely no problems for me so far.
i mean building the tranny should make it better then stock right? better build parts then factory should mean it will last longer than a stock tranny. ( yes i know they will last a long time if treated correctly either way, this is why i say what mods will make it even MORE reliable.)
Old Oct 26, 2012 | 12:24 PM
DsmGuy86's Avatar
I think lie others modding and relability can not always go hand and hand but there are ways they can like me I like to over build for my power like I'm going to do Rods ment for more then my goal and I have injectors rated to 600 hp but I'm at 400+ some call it over kill but I call it safe as long as your not pushing the limits of your parts your fine I obviously have plenty more the. Injectors but just using an example like if you want a safe 600dd car build it to hold 800 so your not pushing what the parts are ment for and obviously a tune can make or break reliability as well
Old Oct 26, 2012 | 02:43 PM
exactly you understand what i ment! put stronger parts in it not because you have to but because you want the motor to be under less stress.
Old Oct 26, 2012 | 03:11 PM
DsmGuy86's Avatar
Yup it's what I would recommend you might pay a lotta extra but to me I'll spend the little extra the jeopardizing my car good luck friend
Old Oct 27, 2012 | 07:04 PM
yep. this is not for me its for people more worried about making their car last as long as possible. th
Old Oct 31, 2012 | 02:24 PM
manolo2011's Avatar
i would say, every 20k miles do all the maintenance services. sounds overkill but will protect your car A LOT!!!...
Old Aug 16, 2023 | 10:42 AM
CanadianHooniga's Avatar
Originally Posted by ToddRhodes
This is just one man's opinion, but the EVO, especially in stock or bolted-form, are still overbuilt. The best "reliability" mod you can get is a tune. From there, the air filter mentioned above sounds good but otherwise, the obvious stuff really is all that's necessary. What is your goal for the car? If you're looking for a 500 awhp car to be as reliable as a 300 awhp car, that's a different story.
Hey everyone, im looking to see what are the best mods to make your evo last longer, whether its the engine lasting longer, to the tranny . basically anything to help prevent problems. Please not obvious things like oil/fluids.
Such as, would building the tranny with lets say a 'shep' make it last longer even if its for a DD?
or things like building the engine.
***edit 8:08pm pacific time, 10/25****
----& lets say the car is stock besides bolt ons, stock turbo on the 8/9/10.
A good reliability mod would be upgrading your baffle kit in the oil pan due to oil starvation issue with high g turns, oil catch can is good as well
Chris725
For Sale - Cars For Sale
11
Aug 24, 2017 11:47 AM
Bryan Ashby
Mar 24, 2016 05:14 PM
MitsuJoe
468
Feb 20, 2016 11:17 AM
MitsuJoe
Aug 1, 2004 01:59 PM
