No camshaft FP stock frame set up
Old Oct 28, 2012 | 01:47 PM
JDM EVO 6's Avatar
I want to daily drive my next evo both my previous evo only got 16mpg
I want around 22-24 mpg with 425 whp on pump is this attainable with good mpg and no cams
Old Oct 28, 2012 | 02:03 PM
SW20Mike's Avatar
Veteran: Air Force
Going to be hard to get your car to run with no camshafts
Old Oct 28, 2012 | 02:06 PM
binky's Avatar
-Bink
Old Oct 28, 2012 | 02:58 PM
codgi's Avatar
What type of Evo is this? VI, VIII, IX? MPG doesn't have much to do with cams or power its all how the car is tuned.
Old Oct 28, 2012 | 03:30 PM
JDM EVO 6's Avatar
ive had a 4 and 8 both wiyh camshaft
gsc s2 and cosworth m2
this one will be a 6 or 8 same engine eitherway
Old Oct 28, 2012 | 03:31 PM
JDM EVO 6's Avatar
I guess ill ask tom for dual maps one for daily and the other for drag
Old Oct 28, 2012 | 03:41 PM
EvoJoeIX's Avatar
I get around 24 mpg in my car running 1200cc injectors....
Its all about the tune
Old Oct 28, 2012 | 04:26 PM
hiboost2.0's Avatar
And what size turbo you have.... Bigger the turbo more time you will be off boost.
Old Oct 28, 2012 | 05:40 PM
EvoJoeIX's Avatar
I dont see why turbo size matters.... I could drive my stock turbo evo so im not in boost just like i do my 35r. I got the same mpg on my stock turbo, not that i even care about gas milage on an evo. Its like wiping before you poop, it makes no sense
evo8426's Avatar
Same here but on stock turbo. I get around 20mpg highway on e85 as well.
I'm running Kelford 272s.
Old Oct 28, 2012 | 06:35 PM
icmanevo's Avatar
I could see turbo size mattering a small amount, but obviously the biggest factor is your tune and driving style. If you go 60 mph all the way to work with no lights you could get 26mpg. haha. if you go 80 and redline it ten times you will get 14.
Old Oct 28, 2012 | 09:18 PM
car_guy507's Avatar
I could see it with a green and on a dynojet...
im on e85, get about 23.5 mpg hwy and made 403 on the vd dynojet on the stock 8 turbo and no cams
Old Oct 29, 2012 | 11:33 AM
JDM EVO 6's Avatar
Most likely I will be doing a Green HTA setup or HTA71 .
Rosica
39
Jun 14, 2017 04:04 PM
formerRX8owner
Dec 3, 2011 10:50 AM
blewbyu
Sep 26, 2011 03:57 PM
Associator
Mar 18, 2010 08:31 PM
Raistlin
Jul 3, 2008 02:35 PM
