Accelerator popped from 65mph and slowed to a stop and stalled
Old Nov 10, 2012 | 08:46 PM
whtan's Avatar
IC Loose?
Cruising on the freeway and all of a sudden I feel a pop from the accelerator pedal and it wouldn't gas and started slowing down until I got safely to the side and stopped.
Old Nov 10, 2012 | 08:55 PM
ak47po's Avatar
Check your IC piping,could have pooped off.
Old Nov 11, 2012 | 01:16 AM
WikdEvo's Avatar
check ic pipes, vacuum lines and around the throttle body area.
Old Nov 11, 2012 | 02:12 AM
whtan's Avatar
From a quick check with just a flashlight and not taking the bumper off the ic pipes are in tact. Will do a more thorough check in the morning, thanks for the replies guys.
Old Nov 11, 2012 | 07:08 AM
pennies_hatchie's Avatar
Check your IC piping to make sure the clamps are tight. Also check your MAF sensor
Old Nov 11, 2012 | 07:26 AM
whitedsm97's Avatar
when my iac died on me, my car would still stay running if i had my foot on the gas pedal. although i didn't have it crap on me while i was driving. you could pull the iac and check to see if it's still intact. mine was all chipped and broke when i took it out. good luck.
Old Nov 11, 2012 | 11:16 AM
whtan's Avatar
ic clamps were way loose and the top one was barely off. After tightening them all up in less then a minute she ran perfectly fine
Old Nov 11, 2012 | 12:25 PM
ReaperX's Avatar
I would suggest carrying around a small tool bag with 6mm-14mm sockets w/ ratchet, needle nose pliers, a regular and phillips head screwdriver, a couple hose clamps, and a flashlight. Those items will help if the situation happens again as those items will fix most things that could strand you and cost a tow
383firstgen
Jul 10, 2012 08:42 AM
newimportowner
Dec 12, 2011 12:54 PM
kenshi1985
17
Aug 26, 2011 09:17 AM
BlackDismay
Oct 30, 2010 04:27 PM
danielskshin
Mar 12, 2010 10:55 AM
