Fuel Gauge not reading, need help
Old Nov 12, 2012 | 11:21 PM
smsevo8's Avatar
I have a 2003 lancer evolution and I installed a Full blown fuel system. I filled up the gas tank and the gas gauge doesn't read all the way to full. What I did, I replaced both fuel gauge sending units and it still doesn't read all the way to full. Is there another way that I can fix that problem?
Old Nov 13, 2012 | 07:09 PM
djdnav's Avatar
When I pulled the fuel pump assembly from my tank to swap the pump I inadvertently tapped the level sensor; which made it read empty when i put everything back together. The float is attached to an arm with a magnet on the end that slides up and down a strip. Make sure the magnet is touching the strip and not bent outward and stuck to something else that is metallic.
hope this helps, GL!
Old Nov 13, 2012 | 09:08 PM
smsevo8's Avatar
Thanks I will look into it. Should I look on both fuel gauge sending units?
Old Nov 14, 2012 | 08:46 AM
djdnav's Avatar
There should only be one. Pull out the entire pump assembly and you should see what's pictures below. Look at the magnetic strip on the end of the float
Arm and verify the magnet sensor is in contact with the strip.
EVOIX-SAV
26
Mar 13, 2017 02:16 PM
Evo_Xela
14
Nov 16, 2016 12:16 PM
ralliart610
Apr 15, 2016 08:45 AM
RealStreet
EvoX 'For Sale' Electronics / Lighting / Audio
Jul 25, 2012 09:58 AM
richie rich
Nov 22, 2011 12:03 PM
