gas gauge doesnt read full (after walbro and tune)
got tuned a few days ago, had a walbro fuel pump installed at the same time. i filled up today but my gas gauge will only go to 3/4 tank. is this normal after a fuel pump instal? and am i getting a fuel tank when i gas up?
It is possible that the installer might have bent the floater sensor and that would send a false reading to the cluster. as far as getting a full tank of gas, if you set the pump handle to fill on its own, it will stop itself at a full tank of gas. sounds like your gonna have to Pull the seats and check the floater for damage.
1 Post
Josh
I would hope any reputable shop wouldn't use tie wraps to hold the fuel pump in place when putting a Walbro in an Evo, it is a direct replacement for the stock fuel pump. I'm betting the float arm was bent when reinstalled or the installer scratched the surface of the "resistance field" on the sending unit. Either way it should be easy to verify. Feel free to PM me if you need any further assistance.
Josh
Josh
Bloomie
10
Jan 28, 2024 09:31 AM
David Buschur
61
Jul 28, 2008 07:20 PM
